Applications
Appearance
This article lists applications built for and with Nix; it constitutes a listing of what may be called the *extended Nix Ecosystem*.
Nix Derivatives
Various applications built on top of Nix:
- fractalide - Reusable Reproducible Composable Software
- musnix - real-time audio modules for NixOS
- nix-bundle - package Nix attributes into single-file executables.
- nix-darwin - NixOS modules for Darwin
- nix-user-chroot - install Nix as an unpriviliged user on any system
- not-os - build a system firmware for embedded devices
- styx - Static site generator in Nix expression language
- nixos-shell (Mic92) - Spawns lightweight nixos vms in a shell (like vagrant)
- nixos-shell (chrisfarms) - like nix-shell, but for NixOS modules. Buildable version can be found in this fork
- extra-container - Run declarative NixOS containers from the command line. Similar to nixos-shell (chrisfarms)
- nixcloud-webservices - nixpkgs extension for web-related technologies
- krops - a stateless alternative to nixops with improved secret management.
- morph - a stateless alternative to nixops, deployment files mostly compatible to nixops's none backend
- nix-bitcoin - Set of NixOS modules to install a bitcoin node with emphasis on security
Nix Tooling
Various tools built for working with the Nix Ecosystem:
- nixpkgs-review - Review nixpkgs pull requests
- nix-update - Swiss army knife for updating nix packages
- nox - Tools to make Nix easier to use
- nix-diff - Compare Nix derivations
- niff - Compare two Nix expressions to determine what attributes changes
- nix-index - Quickly locate nix packages with specific files
- nix-delegate - Convenient utility for distributed Nix builds
- nix-du - Find which gc-roots take disk space in a nix store
- nix-info - Homebrew info querying for Nix
- nix-upgrade-scripts - Tools for Nixpkgs maintainers to upgrade packages
- nixops-manager - NixOps wrapper for Git repositories
- narfuse - FUSE filesystem for mounting Nix archive (NAR) files as a virtual Nix store
- nix-visualize - Visualize the dependencies of a given package
- home-manager - System for managing a user environment using Nix
- nix-home - Utilities for working with user configurations in Nix
- nixGl - A wrapper to run OpenGL applications outside of NixOS
- nix-venient - A collection of convenient commands for working with nix/nixpkgs
- niv - Painless dependencies for Nix projects
- nix-bash-completions - Bash completion for
nix*commands - userscan - Scans directories containing manually compiled programs and registers them with the Nix garbage collector
- nixfmt - A formatter for Nix code
Nix Operations
Operations tools for the Nix Ecosystem:
- Hydra - Nix's official continuous integration and build system.
- kubenix - Kubernetes resource builder written in Nix
- nix-kubernetes - Kubernetes deployment manager written in nix
- Disnix - a microservice architecture built with Nix.
- Hail - a service for pull-based continuous deployment.
- Morph - a NixOS deployment tool
- Nixery - ad-hoc container images from Nix
- Arion - configure Docker Compose with Nix modules
- deploy-rs - a simple multi-profile Nix-flake deploy tool
Alternative nix implementations & parser
- hnix (haskell, parser & evaluator)
- rnix (rust, parser)
- go-nix (go, parser & nix-compatible file hasher)
- nix-idea (java, parser)
See also
- Language-specific package helpers
- Alternative Package Sets
- Get inspiration from other peoples NixOS configuration
- NixOS Packages Search for searching through NixOS packages
