Flake Parts
Appearance
Getting Started
imports = [
# ./module.nix
# inputs.foo.flakeModule
flake = {
# A fallback attribute for non-system specific
# flake attributes (like check, formatter, nixosConfigurations, etc)
See also
- Introduction - flake-parts
