Flake Parts
Revision as of 22:02, 5 August 2024 by Frontear (talk | contribs) (explicitly note documentation on main page)
There is documentation available for a variety of flake-parts powered modules available on https://flake.parts.
Getting Started
    imports = [
      # ./module.nix
      # inputs.foo.flakeModule
    flake = {
      # The usual flake attributes can be defined here, including
      # system-agnostic and/or arbitrary outputs.
Writing Modules
# flake/packages.nix
{ self, inputs, ... }: {
  perSystem = { pkgs, ... }: {
    packages.hello = pkgs.hello;
The above module can then be imported and referenced in the main flake (or other modules)
# flake.nix
    imports = [
      ./flake/packages.nix
On evaluation the flake will expose 4 distinct outputs under packages:
└───packages
    ├───aarch64-darwin
    │   └───hello: package 'hello-2.12.1'
    ├───aarch64-linux
    ├───x86_64-darwin
    └───x86_64-linux
See also
