NixOS Installation Guide
For commodity PC hardware the official manual should covers the most use cases.
Build a custom installation image
NixOS provides an easy way to build a custom variant of the installation image. This might be useful to embed your own ssh key or enable additional features like zfs support. It allows to specify a custom configuration.nix
which is used to build the image
# myiso.nix { config, lib, pkgs, modulesPath, ... }: { imports = [ <nixpkgs/nixos/modules/installer/cd-dvd/installation-cd-minimal.nix> ]; # enable zfs support #boot.supportedFilesystems = [ "zfs" ]; # enable sshd on boot services.openssh = { enable = true; startWhenNeeded = true; }; # the following allows to embed your own ssh key into the image users.extraUsers.root.openssh.authorizedKeys.keys = [ "ssh-ed25519 AaAeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee username@host" ]; ## The following snippet is useful, when static ip addresses are required, ## e.g. for VPS installation # #networking = { # usePredictableInterfaceNames = false; # interfaces.eth0.ip4 = [{ # address = "64.137.201.46"; # prefixLength = 24; # }]; # defaultGateway = "64.137.201.1"; # nameServers = [ "8.8.8.8" ]; #}; }
The full path of the file needs to be passed to nix-build
$ nix-build '<nixpkgs/nixos>' -A config.system.build.isoImage -I nixos-config=/etc/nixos/myiso.nix
The resulting image can be found in result
$ ls result/iso/ nixos-17.09.git.158ec57-x86_64-linux.iso
Install Nixos on VPS/Cloud-Provider
Not all providers allow to upload own images or provide NixOS images for installation. However there are a few ways to install NixOS anyhow.
nixos-in-place and nixos-infect are generic approaches to install NixOS from an existing Linux.
A different approach is to build an kexec-based image to start the installer from an booted linux as shown in this repo
Installation Stories
Add the code you needed to run in order to deploy NixOS at $provider .
Hetzner
Hetzner provides an interface to upload your own ISO-images. However you may want to build your own iso-image, which has openssh with ssh keys due the lack of a remote console. An easier method to install NixOS on Hetzner, is to use the existing integration into NixOps
Digitalocean
On Digitalocean the project nixos-infect can be used to transform an existing installation into NixOS. This method will be also used in NixOps.
Netcup
You can mount your own images similar to hetzner, see the official netcup documentation.
Linode
NixOS is official supported by Linode. Up to date documentation can be obtained from their manual
CloudAtCost
Scaleway
The kexec
method above works well, but bear in mind it only works with the 'virtual' class of servers, as they run under a hypervisor which attaches the disks before the kernel boots. The 'bare-metal' servers rely on a special Linux kernel booting to attach network /dev/nbdX
drives which works only with Scaleway supplied images.
<your vps provider here>
Special hardware
- for embedded Hardware like the Raspberry Pi2 see NixOS on ARM
