NixOS Installation Guide
From NixOS Wiki
Revision as of 23:07, 25 November 2017 by imported>Samueldr (Making the installation media: Updated "Making the installation media")
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
NixOS can be installed on an increasing variety of hardware, including the usual x86-type hardware.
  1. A regular (Intel or AMD) desktop computer, laptop, or physically accessible server can follow the instructions in this page
  2. SBCs, like the Raspberry Pis, and other ARM boards can follow the instructions at NixOS on ARM
  3. Cloud and remote servers will find various instructions at NixOS friendly hosters
Installation method
  1. The classic way, booting from the installation media (described in this page)
This article or section is outdated. Starting from here, the installation guide haven't been revised yet. Further information might be found in the corresponding discussion. Please remove this notice once the information has been updated.
Since NixOS 14.11 the installer ISO is hybrid. This means it is bootable on both CD and USB drives. It also boots on EFI systems, like most modern motherboards and apple systems. The following instructions will assume the standard way of copying the image to an USB drive. When using a CD or DVD, the usual methods to burn to disk should work with the iso.
"Burning" to USB drive
From Linux
  2. Burn with: cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd also works.
From macOS
Template:Outdated:inline
  3. Burn with: sudo dd if=path_to_nixos.iso of=/dev/rdiskX bs=64k
Note: Use rdisk instead of disk, this makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
You could use Disk Utility to write the image but then you'd need to convert it first to a compatible format somehow.
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Build a custom installation image
NixOS provides an easy way to build a custom variant of the installation image. This might be useful to embed your own ssh key or enable additional features like zfs support. It allows to specify a custom configuration.nix which is used to build the image This is explained in Creating a NixOS live CD.
Installing on VPS & Cloud Providers
→ See NixOS friendly hosters
Special hardware
  • for embedded Hardware like the Raspberry Pi2 see NixOS on ARM
