Flake Parts
Revision as of 16:54, 14 September 2025 by Malix (talk | contribs) (add benefit)
The major benefit of flake-parts is being able to write modular flakes with the full power of the module system, with error handled. It is a great option and alternative to flake-utils, a wrapper which is largely discouraged from being used.
There is documentation available for a variety of flake-parts powered modules available on https://flake.parts.
Getting Started
    imports = [
      # ./module.nix
      # inputs.foo.flakeModule
    flake = {
      # The usual flake attributes can be defined here, including
      # system-agnostic and/or arbitrary outputs.
Writing Modules
# flake/packages.nix
{ self, inputs, ... }: {
  perSystem = { pkgs, ... }: {
    packages.hello = pkgs.hello;
The above module can then be imported and referenced in the main flake (or other modules)
# flake.nix
    imports = [
      ./flake/packages.nix
On evaluation the flake will expose 4 distinct outputs under packages:
└───packages
    ├───aarch64-darwin
    │   └───hello: package 'hello-2.12.1'
    ├───aarch64-linux
    ├───x86_64-darwin
    └───x86_64-linux
See also
