Electric guitar interface setup
This guide covers setting up an electric guitar with NixOS to achieve professional, low-latency audio processing. It targets live playing with round-trip latency (RTL) under 6 ms using the modern PipeWire/JACK stack.
⚠️ Safety Warning: Always start with monitoring volume at minimum when testing new signal chains. A sudden, loud feedback loop can be generated during loopback testing. Increase volume gradually only after the plugin is open and stable.
Introduction
The digital signal chain for a guitar consists of:
- Instrument-level signal from Hi-Z pickups.
- Analog-to-Digital conversion via an external audio interface.
- Real-time processing on NixOS using a low-latency kernel and specialized software.
Note: Software-reported latency values are often inaccurate. Physical measurement via loopback test is mandatory for verification.
Installation
System Configuration
Add the following to your /etc/nixos/configuration.nix. This configuration is optimized for high-performance CPUs like the AMD Ryzen 7 9700X (Zen 5 architecture).
{ pkgs, config, ... }:
# 1. Sound Server: PipeWire with JACK/PulseAudio support
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true; # Required for yabridge/wine VST bridging
pulse.enable = true;
jack.enable = true;
wireplumber.enable = true;
# Global low-latency defaults for native JACK clients
extraConfig.pipewire."92-low-latency" = {
"context.properties" = {
"default.clock.rate" = 48000; # Fixed rate avoids resampling latency
"default.clock.quantum" = 128; # ~5ms latency at 48kHz
"default.clock.min-quantum" = 64; # ~2.5ms latency at 48kHz
"default.clock.max-quantum" = 512;
# Crucial: Match low-latency for PulseAudio clients (browsers, Steam/Rocksmith)
extraConfig.pipewire-pulse."92-low-latency" = {
"pulse.properties" = {
"pulse.min.req" = "64/48000"; # Start with 64, not 32, for stability
"pulse.default.req" = "64/48000";
"pulse.max.req" = "128/48000";
# 2. Real-time Scheduling
# RTKit handles real-time privileges via D-Bus/Polkit.
security.rtkit.enable = true;
# Critical: Allow unlimited memlock for real-time audio buffers
security.pam.loginLimits = [
domain = "@audio";
item = "memlock";
type = "-";
value = "unlimited";
domain = "@audio";
item = "rtprio";
type = "-";
value = "95";
users.users.yourname.extraGroups = [ "audio" ]; # Replace 'yourname' with your username
# 3. Kernel and Performance Tweaks
boot.kernelPackages = pkgs.linuxPackages_zen;
boot.kernelParams = [
"threadirqs"
"preempt=full" # Optional: add if experiencing Xruns
"amd_pstate=passive" # Zen 4/5: passive + performance governor = stable freq
# For Intel or older AMD: remove amd_pstate or use "intel_pstate=active"
"usbcore.autosuspend=-1" # Prevent USB audio interface sleep
powerManagement.cpuFreqGovernor = "performance";
# GameMode can elevate priorities for real-time audio applications
programs.gamemode.enable = true;
# 4. NVIDIA Workaround (If applicable)
# For RTX 40/50 series: disable GSP firmware to prevent DPC latency spikes
# hardware.nvidia.powerManagement.enable = false;
# hardware.nvidia.modesetting.enable = true;
# boot.extraModprobeConfig = "options nvidia NVreg_EnableGpuFirmware=0";
# 5. Plugin Search Paths (Crucial for NixOS DAWs)
# Use sessionVariables for GUI apps launched from DE menu
environment.sessionVariables = let
makePluginPath = format = (pkgs.lib.makeSearchPath format [
"/run/current-system/sw/lib"
"${config.users.users.yourname.home}/.nix-profile/lib" # Adjust if using home-manager
]) + ":$HOME/.${format}";
LV2_PATH = makePluginPath "lv2";
VST3_PATH = makePluginPath "vst3";
CLAP_PATH = makePluginPath "clap"; # Modern plugin format, supported by LSP/Chow
# 6. Essential Packages
nixpkgs.config.allowUnfree = true; # Required for REAPER, Tonelib, etc.
# --- Utilities & Routing ---
qpwgraph # Visual patchbay for PipeWire
pavucontrol # Profile selection (Pro Audio mode)
pw-top # Real-time CPU usage per audio node
pw-cli # Modern alternative to pw-metadata
cpupower # CPU frequency scaling controls
alsa-scarlett-gui # Hardware mixer for Focusrite Scarlett (may require firmware)
# --- DAWs ---
ardour
reaper
# --- Plugin Hosts ---
carla # Modular plugin host / pedalboard, supports Windows VST via yabridge
# --- Standalone Guitar Processors ---
guitarix
# tonelib-gfx # NOTE: Currently marked as broken in nixpkgs; install from vendor if needed
# --- Plugins (LV2/CLAP) ---
neural-amp-modeler-lv2 # NAM: loads .nam files from https://tonehunt.org
lsp-plugins # Includes latency meter, compressors, IR loader
calf
dragonfly-reverb
gxplugins-lv2
kapitonov-plugins-pack # Profile-based amp models (KPP)
chow-centaur # Klon Centaur emulation
chow-phaser
# airwindows-lv2 # NOTE: Large package (~400 plugins); consider selective install
# --- Practice & Learning ---
tuxguitar
hydrogen
# --- Windows VST Compatibility ---
yabridge
yabridgectl
wineWowPackages.stable # Use stable, not staging, for VST compatibility
Note on musnix: For advanced users, the musnix flake automates many low-level audio optimizations (such as PREEMPT_RT kernel patching, rtirq tuning, and das_watchdog). If you experience persistent Xruns with the standard Zen kernel, replacing manual tweaks with musnix.enable = true; is highly recommended. Warning: musnix may require replacing your kernel and can affect compatibility with Steam/Wine applications.
Applying Changes
sudo nixos-rebuild switch
# Apply PipeWire configuration changes (required after rebuild):
systemctl --user restart pipewire pipewire-pulse wireplumber
Hardware & Connection
Standard PC line-ins are unsuitable for guitar. Use a dedicated interface with a Hi-Z (Instrument) input.
Verified compatible devices (2026)
| Device | Notes |
| Focusrite Scarlett Solo (4th Gen) | Plug-and-play. Use alsa-scarlett-gui for hardware monitoring. May require firmware update.
| MOTU M2 / M4 | Native ALSA kernel support for direct hardware mixer control via alsamixer. Exceptionally stable USB-C latency.
| Universal Audio Volt 276 | Reliable USB-C class-compliant interface. |
| Arturia MiniFuse 1 | Stable performance under PipeWire. |
Hardware Rules
- Connect the interface directly to the motherboard (rear panel USB 3.0/3.2). Avoid USB hubs — they add latency and can cause Xruns.
- Use a high-quality, shielded USB cable. Audio dropouts are frequently caused by cheap cables acting as antennas for electrical interference.
- Disable Bluetooth during live playing:
rfkill block bluetooth. BT audio stack can generate interrupt storms causing Xruns.
Verification
lsusb # Confirm hardware connection
arecord -l # Verify ALSA sees the capture input
aplay -l # Verify ALSA sees the playback output
# For detailed interface capabilities:
arecord --dump-hw-params -D hw:<card>,<device>
Audio Server Setup
Pro Audio Profile
To achieve minimal latency, you must bypass standard software mixing:
- Open
pavucontrol. - Go to Configuration tab.
- Set your interface profile to Pro Audio.
Note: If "Pro Audio" profile is missing, ensure pipewire-alsa is installed and restart PipeWire. This profile disables software mixing and enables hardware-exclusive mode, critical for achieving lowest latency.
Dynamic Buffer Control
You can change latency without rebuilding the system. Note: these settings affect PipeWire clients only; ALSA-direct applications (like Ardour with ALSA backend) use their own buffer settings.
# Modern syntax (PipeWire 0.3.65+):
pw-cli set-param 0 clock.force-quantum 64/48000
# Verify current settings:
pw-cli dump settings | grep -E "quantum|rate"
# Alternative: use wpctl (WirePlumber CLI)
wpctl set-default-rate 48000
Use pw-top in a separate terminal to monitor which applications are consuming the most DSP processing time. Look for the ERR column — values >0 indicate Xruns.
Software Guide: Choosing Your Rig
This section explains the available software for guitar processing on NixOS, organized by purpose.
Digital Audio Workstations (DAWs)
| Software | Purpose | Notes |
| Ardour | Professional recording, mixing, editing | For absolute minimum RTL, use ALSA backend (bypasses PipeWire). Warning: ALSA locks device exclusively — no other app can produce sound. |
| REAPER | Commercial DAW, lightweight, scriptable | Uses PipeWire-JACK natively. Excellent Linux support. Unlimited trial. |
Amp Simulators & Neural Modelers
Neural Amp Modeler (NAM) (neural-amp-modeler-lv2) |
Loads .nam files — AI captures of real tube amps |
No built-in GUI in LV2 version. In Carla/Ardour: look for atom:Path parameter and point to your .nam file. Models: tonehunt.org
| Kapitonov Plugins Pack (KPP) | Profile-based traditional amp modeling | Excellent for classic rock/metal. Lower CPU than neural nets. |
| Guitarix | All-in-one virtual amp + pedals | Standalone or LV2. Good for quick practice. |
⚠️ Critical: Neural amps (NAM, KPP) only model preamp/poweramp. You must load a Cabinet IR (via LSP IR Loader or similar) to get a usable guitar tone. Without IR, it sounds like a swarm of bees.
Effects Plugins
| Plugin Pack | Key Features |
| LSP Plugins | Professional EQ, compression, gating. Includes LSP Latency Meter and LSP Impulse Response Loader (required for cabinet sims). |
| Dragonfly Reverb | High-quality algorithmic reverb (Hall, Room, Plate). |
Chow Plugins (chow-centaur, chow-phaser) |
High-fidelity emulations of classic pedals using RNN/WDF. |
| Calf Studio Gear | Vintage-style effects with "warm" analog character. |
| GxPlugins.lv2 | Guitarix project pedals (distortion, overdrive, fuzz) as standalone LV2. |
Modular Hosts
| Carla | Modular plugin host. Chain plugins visually: Input → Tuner → NAM → IR Loader → Reverb → Output. Hosts Windows VSTs via yabridge. |
| qpwgraph | Visual patchbay for PipeWire/JACK. Manually connect hardware inputs to software hosts (PipeWire does not auto-connect). |
| Tool | Purpose |
| yabridge + yabridgectl | Bridge for running Windows VST2/VST3 plugins on Linux via Wine. Essential for commercial plugins (Neural DSP, STL Tones, Amplitube). |
# After installing Windows plugins via Wine:
yabridgectl sync # Required to register plugins with Linux hosts
Note: Ensure glibc versions match between Wine and system. Check with ldd /path/to/plugin.dll.
Rocksmith 2014 Remastered (Optional)
Rocksmith 2014 runs on NixOS via Proton and PipeWire.
Connection Options
| Method | Pros | Cons |
| Real Tone Cable | Official, plug-and-play | Proprietary, limited to 48kHz |
| Your Audio Interface + RS_ASIO | Use professional interface, any sample rate | Requires modding game files |
Setup Steps
- Install dependencies:
# In configuration.nix:
programs.steam.enable = true;
programs.gamemode.enable = true; # For launch option below
- Steam Launch Options (force low latency + real-time priority):
PIPEWIRE_LATENCY=128/48000 gamemoderun %command%
Start with 128/48000 (~5ms). If stable, try 64/48000 (~2.5ms). Values <64 may cause crashes.
- Sample Rate: Rocksmith strictly requires 48000 Hz. Do not force 96000 Hz while playing.
- If using Real Tone Cable and experiencing issues, try ALSA backend as fallback (warning: exclusive device access):
# Only use if Pulse backend fails. May silence other apps.
protontricks 221680 sound=alsa
- For interface users (no Real Tone Cable): Install RS_ASIO mod to enable direct interface support. This bypasses the 48kHz limitation and allows using your professional interface.
Measuring Latency
Never trust software reports. Always perform a physical loopback test.
Procedure
⚠️ Warning: Before starting, turn output volume on your audio interface all the way down. A sudden, loud feedback loop can be generated if the connection is unstable. Increase volume gradually only after the plugin is open.
- Connect a cable from your interface Output back into the Input (use a TS/TRS patch cable).
- Launch LSP Latency Meter:
# Option A: Via Carla (recommended for beginners)
carla # Add plugin "LSP Latency Meter Stereo", connect wires
# Option B: Via jalv (terminal)
jalv http://lsp-plug.in/plugins/lv2/latency_meter_stereo
- Play a sharp transient (string scratch) and read the Round-trip Latency (RTL) value.
Target Values
| Latency | Perception |
| < 5 ms | Professional / Imperceptible |
| 5–10 ms | Acceptable for practice |
| > 12 ms | Noticeable "lag", difficult to play in time |
Note: If measured latency exceeds calculated buffer latency (buffer / sample_rate) * 2 * 1000, check: USB interface hardware buffers, PipeWire extra quantum settings, kernel interrupt latency.
Troubleshooting
| Symptom | Cause & Solution |
| Xruns (audio glitches) | • Ensure powerManagement.cpuFreqGovernor = "performance" is active (cpupower frequency-info).• Check pw-top for high-CPU nodes.• Close browsers/heavy apps during playing. • Disable Wi-Fi: sudo modprobe -r iwlwifi.• As last resort: add processor.max_cstate=1 to boot.kernelParams (disables CPU sleep — high power draw).
| No sound | • Check qpwgraph — PipeWire does not auto-connect hardware.• Verify Pro Audio profile in pavucontrol.• Run sudo lsof /dev/snd/* to find conflicting processes.
| DAW cannot find plugins | • Ensure environment.sessionVariables block is applied. Log out/in after rebuild.• Verify paths: echo $LV2_PATH.• Check plugin installation: ls ~/.lv2, ls /run/current-system/sw/lib/lv2.
| NVIDIA audio glitches | • Disable GPU power management: hardware.nvidia.powerManagement.enable = false;• For RTX 40/50 series: add boot.extraModprobeConfig = "options nvidia NVreg_EnableGpuFirmware=0";• Prefer X11 over Wayland for lowest latency. |
| Bluetooth causing Xruns | • Disable Bluetooth stack: rfkill block bluetooth during live sessions.
| PipeWire config not applying | • Restart user services after rebuild: systemctl --user restart pipewire wireplumber.• Check for WirePlumber overrides: wpctl status.
Quick Start Checklist
Before playing, verify:
# 1. CPU governor is performance
cpupower frequency-info | grep "current policy" # Should show "performance"
# 2. PipeWire buffer is set
pw-cli dump settings | grep quantum # Should show 64 or 128
# 3. No Xruns reported
pw-top | grep -E "ERR|XRUN" # Should show 0 or empty
# 4. Pro Audio profile active
pavucontrol # Configuration tab → your interface → Pro Audio
# 5. Plugin paths are set (for GUI apps)
echo $LV2_PATH # Should include /run/current-system/sw/lib/lv2
See Also
- PipeWire — Official NixOS PipeWire documentation
- musnix — Deep NixOS audio optimizations module
- LinuxMusicians Forum — Community support
- ToneHunt — Free NAM model library
- RS_ASIO — Rocksmith interface mod
