Electric guitar interface setup
Revision as of 10:43, 23 July 2026 by Mr.Smith1970 (talk | contribs) (Update electric guitar interface setup: add new amp sims, fix config structure)
This guide covers setting up an electric guitar with NixOS to achieve professional, low-latency audio processing. It targets live playing with round-trip latency (RTL) under 6 ms using the modern PipeWire and WirePlumber stack.
Warning: Always start with monitoring volume at minimum when testing new signal chains. A sudden, loud feedback loop can be generated during loopback testing. Increase volume gradually only after the plugin is open and stable.
The digital signal chain for a guitar consists of:
  1. Instrument-level signal from Hi-Z pickups.
  2. Analog-to-Digital conversion via an external audio interface.
  3. Real-time processing on NixOS using a low-latency kernel and specialized software.
Note: Software-reported latency values are often inaccurate. Physical measurement via a loopback test is mandatory for verification.
Installation
Add the following snippets to your /etc/nixos/configuration.nix or your flake. This configuration is optimized for high-performance CPUs (e.g., AMD Ryzen 7 9700X) running NixOS 26.05 "Yarara" or newer.
Sound server
Configure PipeWire with global low-latency defaults and disable node suspension to prevent audio pops on USB interfaces. Note that legacy pulse.min.req parameters are deprecated in PipeWire 0.3.80+ and handled globally by default.clock.*.
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true; # Required for yabridge/wine VST bridging
    pulse.enable = true;
    jack.enable = true;
    wireplumber.enable = true;
    # Global low-latency defaults
    extraConfig.pipewire."92-low-latency" = {
      "context.properties" = {
        "default.clock.rate" = 48000;       # Fixed rate avoids resampling latency
        "default.clock.quantum" = 128;      # ~5ms latency at 48kHz
        "default.clock.min-quantum" = 32;   # Allows top-tier interfaces to achieve ~1.5ms
        "default.clock.max-quantum" = 512;
    # Disable node suspension and fix crackling on problematic USB interfaces
    wireplumber.extraConfig."99-disable-suspend" = {
      "monitor.alsa.rules" = [{
        matches = [
          { "node.name" = "~alsa_input.*"; }
          { "node.name" = "~alsa_output.*"; }
        actions = {
          update-props = {
            "session.suspend-timeout-seconds" = 0;
            # Optional: Tweak by trial-and-error if crackling occurs on specific USB interfaces.
            # Do not apply globally without testing, as it may break built-in audio.
            # "api.alsa.period-size" = 2;
            # "api.alsa.headroom" = 8192;
Real-time scheduling
RTKit handles real-time privileges via D-Bus/Polkit. Critical PAM limits must be set to allow unlimited memlock and high real-time priority for audio buffers.
  security.rtkit.enable = true;
  security.pam.loginLimits = [
    { domain = "@audio"; item = "memlock"; type = "-"; value = "unlimited"; }
    { domain = "@audio"; item = "rtprio"; type = "-"; value = "99"; }
    { domain = "@audio"; item = "nice"; type = "-"; value = "-19"; }
  users.users.yourname.extraGroups = [ "audio" ]; # Replace 'yourname' with your username
Kernel and performance
Modern mainline kernels include merged PREEMPT_RT patches. Dynamic preemption (preempt=full) provides best-effort low latency without the overhead of a dedicated RT kernel. CPU frequency scaling must be locked to prevent sleep-state latency spikes.
  boot.kernelParams = [
    "threadirqs"
    "preempt=full"
    "amd_pstate=active"         # Zen 4/5: active mode provides best EPP and responsiveness
    "usbcore.autosuspend=-1"    # Prevent USB audio interface sleep
  services.power-profiles-daemon.enable = false;
  powerManagement.cpuFreqGovernor = "performance";
  programs.gamemode.enable = true; # Can elevate priorities for real-time audio applications
Plugin search paths
Crucial for NixOS DAWs to find plugins reliably in Wayland/X11 sessions.
  environment.variables = let
    makePluginPath = format:
      (pkgs.lib.makeSearchPath format [
        "$HOME/.nix-profile/lib"
        "/run/current-system/sw/lib"
        "/etc/profiles/per-user/$USER/lib"
      ]) + ":$HOME/.${format}";
    LV2_PATH = makePluginPath "lv2";
    VST3_PATH = makePluginPath "vst3";
    CLAP_PATH = makePluginPath "clap";
System packages
  nixpkgs.config.allowUnfree = true; # Required for REAPER, Bitwig Studio, etc.
    # --- Utilities & routing ---
    qpwgraph            # Visual patchbay for PipeWire (v1.0.3+)
    pwvucontrol         # Modern native PipeWire volume control
    pavucontrol         # Fallback for Pro Audio profile selection
    pw-top              # Real-time CPU usage per audio node
    easyeffects         # System-wide real-time EQ and effects
    # --- DAWs ---
    ardour
    reaper
    bitwig-studio       # Native Linux commercial DAW, excellent CLAP support
    # --- Plugin hosts ---
    carla               # Modular plugin host, supports Windows VST via yabridge
    # --- Standalone guitar processors ---
    guitarix            # Includes native NAM and RTNeural module support
    # --- Plugins (LV2/CLAP) ---
    neural-amp-modeler-lv2  # NAM: AI captures of real tube amps
    proteus               # Neural network modeling (LSTM) by GuitarML
    lsp-plugins           # Professional EQ, compression, IR loader (now available in CLAP)
    calf                  # Vintage-style effects
    dragonfly-reverb      # High-quality algorithmic reverb
    gxplugins-lv2         # Guitarix project pedals as standalone LV2
    kapitonov-plugins-pack # Profile-based traditional amp modeling (VST3/LV2)
    chow-centaur          # Klon Centaur emulation
    chow-phaser           # Phaser emulation
    # --- Practice & learning ---
    tuxguitar
    hydrogen
    # --- Windows VST compatibility ---
    yabridge
    (yabridgectl.override { wine = wineWow64Packages.stable; }) # Explicit Wine path
    wineWow64Packages.stable  # Use wineWow64Packages, as wineWowPackages is deprecated
Configuration
Applying changes
sudo nixos-rebuild switch
# Apply PipeWire configuration changes (required after rebuild):
systemctl --user restart pipewire wireplumber
Pro audio profile
To achieve minimal latency, you must bypass standard software mixing:
  1. Open pavucontrol.
  2. Go to the Configuration tab.
  3. Set your interface profile to Pro Audio.
If the "Pro Audio" profile is missing (or listed as "Digital Stereo" / "Multichannel" depending on the interface), ensure pipewire-alsa is installed and restart PipeWire. This profile disables software mixing and enables hardware-exclusive mode, which is critical for achieving the lowest latency.
Dynamic buffer control
You can change latency dynamically without rebuilding the system. Note that this setting is temporary and will be lost after restarting PipeWire.
# Force quantum to 64 samples (pw-metadata syntax):
pw-metadata -n settings 0 clock.force-quantum 64
# Verify current settings:
Use pw-top in a separate terminal to monitor which applications are consuming the most DSP processing time. Look for the ERR column — values greater than zero indicate Xruns.
Hardware and connection
Standard PC line-ins are unsuitable for guitar. Use a dedicated interface with a Hi-Z (Instrument) input.
Warning: Input headroom and clipping: Budget interfaces (e.g., Focusrite Scarlett, MOTU M2/M4, Audient iD series) have limited headroom on their Hi-Z inputs. Modern high-output passive or active pickups can cause digital clipping at the ADC stage before the signal reaches 0 dB in your DAW, even with the gain knob at minimum. Solution: Use a passive DI-box (e.g., Palmer PAN 01, ART DTI), an inline attenuator (pad), or physically lower your guitar's pickups to reduce the output signal.
Verified compatible devices
Device Notes
Focusrite Scarlett 4th Gen (Solo/2i2/4i4) Plug-and-play. Requires disabling MSD Mode (hold 48V button while powering on). alsa-scarlett-gui works natively without extra packages.
Focusrite Scarlett 4th Gen (16i16/18i16/18i20) Requires kernel ≥6.14, fcp-support, and a firmware update via alsa-scarlett-gui.
MOTU M2 / M4 Native ALSA kernel support (requires kernel ≥6.1+). Direct hardware mixer control via alsamixer. Exceptionally stable USB-C latency.
Universal Audio Volt 276 Reliable USB-C class-compliant interface.
Arturia MiniFuse 1 Stable performance under PipeWire.
Audient iD4 / iD14 (All Generations) Fully functional on NixOS. No special drivers needed.
Hardware rules
  1. Connect the interface directly to the motherboard (rear panel USB 3.0/3.2). Avoid USB hubs — they add latency and can cause Xruns.
  2. Use a high-quality, shielded USB cable. Audio dropouts are frequently caused by cheap cables acting as antennas for electrical interference.
  3. Disable Bluetooth during live playing: rfkill block bluetooth. The BT audio stack can generate interrupt storms causing Xruns.
  4. Limit GPU FPS: High frame rates in 3D applications or GUI-heavy plugins can generate PCIe interrupt storms causing DPC latency spikes. Cap your FPS or enable VSync in your compositor.
Verification
lsusb                    # Confirm hardware connection
arecord -l               # Verify ALSA sees the capture input
aplay -l                 # Verify ALSA sees the playback output
Software guide
This section explains the available software for guitar processing on NixOS, organized by purpose.
Digital audio workstations
Software Purpose Notes
Ardour Professional recording, mixing, editing For absolute minimum RTL (<5ms), use the ALSA backend (bypasses PipeWire). Warning: ALSA locks the device exclusively — no other app can produce sound.
REAPER Commercial DAW, lightweight, scriptable Uses PipeWire-JACK natively. Excellent Linux support. Unlimited trial.
Bitwig Studio Modern commercial DAW Native Linux support. Superior CLAP format integration. Note: Direct ALSA backend on NixOS may require manual USB latency compensation; PipeWire-JACK is often more stable out-of-the-box.
Amp simulators and neural modelers
Neural Amp Modeler (NAM) LV2 plugin. Loads .nam files AI captures of real tube amps. Now supports Architecture 2 (A2) (June 2026), offering higher accuracy with lower CPU usage. Models: TONE3000 (formerly ToneHunt).
Proteus LV2 plugin. Neural network modeling (LSTM) By GuitarML. Faster preset switching than NAM.
Kapitonov Plugins Pack (KPP) Profile-based traditional amp modeling Excellent for classic rock/metal. Lower CPU than neural nets. Available in LV2 and VST3.
Guitarix All-in-one virtual amp + pedals Standalone or LV2. Now includes native modules for loading .nam and RTNeural (.json/.aidax) models.
Note: CRITICAL for KPP: The input level at the beginning of the Kapitonov Plugins Pack chain must be strictly around -20 dB, otherwise the plugins will distort incorrectly. Use a meter plugin (e.g., LSP Meter) to verify.
Warning: Neural amps (NAM, Proteus, KPP) only model preamp/poweramp. You must load a Cabinet IR (via LSP IR Loader or similar) to get a usable guitar tone. Without an IR, the sound will be thin and unpleasant.
Effects plugins
Plugin Pack Key Features
LSP Plugins Professional EQ, compression, gating. Includes LSP Latency Meter and LSP Impulse Response Loader. Now available in CLAP format.
Dragonfly Reverb High-quality algorithmic reverb (Hall, Room, Plate).
Chow Plugins High-fidelity emulations of classic pedals using RNN/WDF.
Calf Studio Gear Vintage-style effects with "warm" analog character.
GxPlugins.lv2 Guitarix project pedals (distortion, overdrive, fuzz) as standalone LV2.
Modular hosts
Software Purpose
Carla Modular plugin host. Chain plugins visually: Input → Tuner → NAM → IR Loader → Reverb → Output. Hosts Windows VSTs via yabridge.
qpwgraph Visual patchbay for PipeWire/JACK (v1.0.3+). Manually connect hardware inputs to software hosts (PipeWire does not auto-connect).
Tool Purpose
yabridge + yabridgectl Bridge for running Windows VST2/VST3/CLAP plugins on Linux via Wine. Essential for commercial plugins (Neural DSP, STL Tones, Amplitube). Note: yabridge 5.0+ supports CLAP, and yabridgectl sync registers them in ~/.clap/yabridge.
PipeASIO Experimental ASIO-to-PipeWire driver (v1.2.3+). Bypasses JACK entirely, connecting ASIO directly to PipeWire via libpipewire-0.3. Highly recommended for Windows DAWs (FL Studio, Ableton) or games in Proton, as it bypasses the missing libjack.so.0 in the Steam Runtime container.
# After installing Windows plugins via Wine:
yabridgectl sync  # Required to register plugins with Linux hosts
Tips and tricks
Rocksmith 2014
Rocksmith 2014 runs on NixOS via Proton and PipeWire. There are two distinct approaches depending on your preferred audio routing. Do not mix them, as they are mutually exclusive.
Approach A: Declarative via nixos-rocksmith (WineASIO + JACK)
This method uses the nixos-rocksmith flake, which patches Steam to preload libjack.so and use RS_ASIO with WineASIO.
  1. Add the module to your flake and enable it:
programs.steam = {
  rocksmithPatch.enable = true;
  1. Steam Launch Options:
LD_PRELOAD=/usr/lib32/libjack.so PIPEWIRE_LATENCY=128/48000 %command%
Approach B: PipeASIO (Direct ASIO to PipeWire)
This method bypasses JACK and WineASIO entirely. It is the preferred experimental method for Steam Runtime, as it does not require libjack.so.
  1. Build and install PipeASIO under $HOME/.local (Proton cannot see system-wide /usr/lib/wine).
  2. Register the driver in the game's Wine prefix:
env WINEPREFIX="$HOME/.steam/steam/steamapps/compatdata/221680/pfx" pipeasio-register
  1. Steam Launch Options (point Proton to the local Wine libs):
WINEDLLPATH=$HOME/.local/lib/wine PROTON_USE_WOW64=1 gamemoderun %command%
Note: PROTON_USE_WOW64=1 is required for 32-bit applications (like Rocksmith 2014) when using newer WoW64 architectures in Proton Experimental or Wine 9.0+. It may not be needed for older stable Proton versions.
Note: Rocksmith strictly requires a sample rate of 48000 Hz. Do not force 96000 Hz while playing.
Measuring latency
Always perform a physical loopback test.
Warning: Before starting, turn output volume on your audio interface all the way down. A sudden, loud feedback loop can be generated if the connection is unstable. Increase volume gradually only after the plugin is open.
  1. Connect a cable from your interface Output back into the Input (use a TS/TRS patch cable).
  2. Launch LSP Latency Meter:
# Option A: Via Carla (recommended for beginners)
carla  # Add plugin "LSP Latency Meter Stereo", connect wires
# Option B: Via jalv (terminal)
jalv http://lsp-plug.in/plugins/lv2/latency_meter_stereo
  1. Play a sharp transient (string scratch) and read the Round-trip Latency (RTL) value.
Target values:
  • < 5 ms: Professional / Imperceptible
  • 5–10 ms: Acceptable for practice
  • > 12 ms: Noticeable "lag", difficult to play in time
Quick start checklist
Before playing, verify:
# 1. CPU governor is performance
cpupower frequency-info | grep "current policy"  # Should show "performance"
# 2. PipeWire buffer is set
pw-metadata -n settings  # Should show clock.force-quantum 64 or 128
# 3. No Xruns reported (run pw-top in batch mode for clean output)
pw-top -b -n 1 | grep ERR  # Should show 0 or empty
# 4. Pro Audio profile active
pavucontrol  # Configuration tab → your interface → Pro Audio
# 5. Plugin paths are set (for GUI apps)
echo $LV2_PATH  # Should include /run/current-system/sw/lib/lv2
Troubleshooting
Symptom Cause & Solution
Xruns (audio glitches) Ensure powerManagement.cpuFreqGovernor = "performance" is active. Check pw-top for high-CPU nodes. Close browsers/heavy apps during playing. Disable Wi-Fi: sudo modprobe -r <your_wifi_driver> or rfkill block wifi to prevent interrupt storms. As a last resort, add processor.max_cstate=1 to boot.kernelParams (disables CPU sleep — results in extreme power draw and heat, use with caution).
Input clipping / digital distortion High-output pickups are overloading the interface's Hi-Z preamp. Use a passive DI-box, an inline pad, or lower your guitar's volume/pickup height.
No sound Check qpwgraph — PipeWire does not auto-connect hardware. Verify Pro Audio profile in pavucontrol. Run sudo lsof /dev/snd/* to find conflicting processes.
DAW cannot find plugins Ensure environment.variables block is applied. Log out/in after rebuild. Verify paths: echo $LV2_PATH.
Audio pops a few seconds after playback stops WirePlumber suspends the ALSA node after 5 seconds of inactivity. Ensure session.suspend-timeout-seconds = 0 is set in wireplumber.extraConfig.
USB crackling / dropouts Increase api.alsa.period-size and api.alsa.headroom in the WirePlumber extraConfig (see Installation section).
GPU causing audio glitches Disable GPU power management. Limit FPS in games/DAW to reduce PCIe interrupt storms (DPC latency). Prefer X11 session if you experience visual glitches with older JUCE-based plugins under Wayland.
Bluetooth causing Xruns Disable Bluetooth stack: rfkill block bluetooth during live sessions.
PipeWire config not applying Restart user services after rebuild: systemctl --user restart pipewire wireplumber. Check for WirePlumber overrides: wpctl status.
See also
  • PipeWire — Official NixOS PipeWire documentation
  • Audio production — General audio configuration and plugin paths
  • musnix — Deep NixOS audio optimizations module
  • LinuxMusicians Forum — Community support
  • TONE3000 — Largest library of NAM models and IRs (formerly ToneHunt)
  • PipeASIO — ASIO to PipeWire bridge for Wine/Proton
  • linux-rocksmith — Comprehensive guide to Rocksmith on Linux
  • Rustortion — Modern Rust-based amp sim (experimental, build from source)
  • AIDA-X — RTNeural-based amp model player (experimental)
  • Ratatouille.lv2 — Dual neural modeler (experimental)
