Fingerprint scanner
Revision as of 12:16, 6 November 2026 by Intiitni (talk | contribs) (System Settings instead of System Monitor)
Fingerprint scanners (on laptop computers) can be used to unlock devices instead of using passwords.
Install
❄︎ /etc/nixos/configuration.nix
{ config, lib, pkgs, ... }: {
  # Install the driver
  services.fprintd.enable = true;
  # If simply enabling fprintd is not enough, try enabling fprintd.tod...
  services.fprintd.tod.enable = true;
  # ...and use one of the next four drivers
  services.fprintd.tod.driver = pkgs.libfprint-2-tod1-goodix; # Goodix driver module
  # services.fprintd.tod.driver = pkgs.libfprint-2-tod1-elan; # Elan(04f3:0c4b) driver
  # services.fprintd.tod.driver = pkgs.libfprint-2-tod1-vfs0090; # (Marked as broken as of 2025/04/23!) driver for 2016 ThinkPads
  # services.fprintd.tod.driver = pkgs.libfprint-2-tod1-goodix-550a; # Goodix 550a driver (from Lenovo)
  # however for focaltech 2808:a658, use fprintd with overidden package (without tod)
  # services.fprintd.package = pkgs.fprintd.override {
  #   libfprint = pkgs.libfprint-focaltech-2808-a658;
  # this package is deprecated as of 2026 due to copyright reasons, you may search the internet for archived caches
Enroll fingerprint
Fingerprint enrollment can be done via the CLI or the UI in the Desktop Environment if available.
CLI
$ fprintd-enroll
Gnome
In Gnome, the the fingerprints can be configured through the Settings application.
  1. Open Gnome Settings
  2. Scroll down to System
  3. Enter the Users menu
  4. Enter Fingerprint Login and add fingerprints
Note: If the Fingerprint Login item is not available, the fprintd driver might not be configured correctly.
KDE Plasma
In KDE Plasma, the fingerprints can be configured through the Settings application.
  1. Open System Settings
  2. On the menu on the left, scroll down to Users and enter it
  3. Select your user
  4. Enter Configure Fingerprint Authentication and follow the instructions to add your fingerprints
Note: If the Configure Fingerprint Authentication item is not available, the fprintd driver might not be configured correctly.
Login
While services.fprintd.enable = true; enables fingerprint login for the majority of display manager via the corresponding PAM module, it can sometimes disable the ability to login using a password. This is addressed in the GitHub issue 171136. In that issue, a possible workaround is addressed using a custom PAM module for the gnome display manager:
security.pam.services.login.fprintAuth = false;
security.pam.services.gdm-fingerprint = lib.mkIf (config.services.fprintd.enable) {
  text = ''
    auth       required                    pam_shells.so
    auth       requisite                   pam_nologin.so
    auth       requisite                   pam_faillock.so      preauth
    auth       required                    ${pkgs.fprintd}/lib/security/pam_fprintd.so
    auth       optional                    pam_permit.so
    auth       required                    pam_env.so
    auth       [success=ok default=1]      ${pkgs.gdm}/lib/security/pam_gdm.so
    auth       optional                    ${pkgs.gnome-keyring}/lib/security/pam_gnome_keyring.so
    account    include                     login
    password   required                    pam_deny.so
    session    include                     login
    session    optional                    ${pkgs.gnome-keyring}/lib/security/pam_gnome_keyring.so auto_start
