Revision as of 02:47, 21 September 2021 by imported>Nix (replace whitespace with template)
rec { } Nix expressions The { } block contains "mutually recursive" attributes, which means they can refer to each other. Composing the Hello Package
Derivation Nix A Nix expression which describes a build action. When evaluated, it creates one or more entries in the Nix Store. The nix-instantiate command is the command which creates entries in the Nix Store, while the nix-env and nix-build commands are its user-friendly interface. Nix Manual: Glossary -> Derivation
Nix Manual: Derivation
User Environment Nix A set of "active" applications. These applications often exist in the Nix store. A single Nix user may have multiple User Environments. Nix Manual: Glossary
User Profile Nix A user's currently selected User Environment. Nix Manual: Glossary
Generation
Nix A past revision of a user's environment. This term connotes the cloning and modification of an existing user environment. Nix's environment rollback facilities rely on Generations. Nix Manual: Profiles
NixPkgs Release Notes
Template:Bottom whitespace
