Appearance
Term | Context | Meaning | Related Links |
User Environment | Nix | A set of "active" applications. These applications usually exist in the Nix store. A single Nix user may have multiple user environments. Profiles and generations are closely related. |
Nix Manual - Basic Package Management chapter |
(User) Profile | Nix | Profiles simplify managing and switching between user environments, and thus control which applications and system configurations are in active use. Generally, a profile is a link to a generation, and the corresponding profiles folder collects a list of generations. A standalone Nix installation (i.e. on a Linux distro that is not NixOS) operates mainly on user profiles. In NixOS, there is also a system profile that manages system-wide configuration (e.g. /etc, the kernel, initrd, systemd). Other tools like Home Manager also have their own profiles. By default, a user's active profile is stored at ~/.nix-profile:
$ ls -l ~/.nix-profile
Nix Manual: Profiles Nix Pills - The first profile |
Generation | Nix | An instance of a user environment. When a user makes any change to their environment, such as installing or removing packages, a new generation of the environment is created instead of modifying the environment in-place. This ensures that updates are atomic and the user can easily roll-back to any previous generation if something goes wrong. The current generation is a user's currently active user profile. | Nix Manual: Profiles |
Derivation | Nix | A Nix expression which describes a build action. Derivations are analogous to package definitions in other package managers. High-level derivations (such as the ones describing packages in Nixpkgs) get evaluated into low-level derivations (called store derivations), for instance by using the nix-instantiate command. nix-store --realise run the build commands described in the derivation, producing one or more output paths. nix-build is a user-friendly wrapper for the previous two commands.
Nix Manual: Glossary - Derivation Nix Manual: Derivation |
Output path | Nix | A store path produced by a derivation. These are generally analogous to built packages, or pieces of them.
$ ls -ld /nix/store/*-firefox-9*/
rec { }
Nix expressions | The { } block contains "mutually recursive" attributes, which means they can refer to each other.
Composing the Hello Package |
expression evaluator
Nix | The part of the Nix program which reads and evaluates a Nix expression. | Nix Manual: Common Options --arg Nix Manual: Built-in Functions |
stdenv
Nix expressions | An attribute which contains things expected in the most basic Unix environment. (e.g. Bash shell, gcc , cp , tar , grep , etc.)
all-packages.nix: stdenv = ]
config.nix or nixpkgs-config.nix
NixOS Wiki | A Nix expression retrieved by and applied to the all-packages.nix Nix expression. This file enables an end-user to customize the Nix expressions contained in the community-owned NixPkgs list or to define entirely new Nix expressions to use with Nix commands. This file's path can be overridden by the NIXPKGS_CONFIG environment variable.
all-packages.nix: config
attribute path | nix-env takes this if you pass the `-A` flag [1] | an unambiguous identifier for a package | |
symbolic package name | [2] | This string represents what you commonly think of as a package. There can be multiple packages with the symbolic name "hello". | |
selector | this term is used in nix-env error messages [3], it seems to be actually a DrvName struct [4] (a derivation name) | see "symbolic package name" | |
selection path | nix-shell error message [5] | see "attribute path"[6] | |
derivation name | manual[7], source code [8] | see "symbolic package name" | |
package name | IRC[9] | see "symbolic package name" | |
attribute selection path | source[10] | see "attribute path" |
