Revision as of 12:25, 25 February 2025 by FuzzyBot (talk | contribs) (Updating to match new version of source page)
User Environment
Nix A set of "active" applications. These applications usually exist in the Nix store. A single Nix user may have multiple user environments. Profiles and generations are closely related.
Nix Manual - Profiles chapter
Nix Manual - nix-env
(User) Profile Nix Profiles simplify managing and switching between user environments, and thus control which applications and system configurations are in active use. Generally, a profile is a link to a generation, and the corresponding profiles folder collects a list of generations. A standalone Nix installation (i.e. on a Linux distro that is not NixOS) operates mainly on user profiles. In NixOS, there is also a system profile that manages the system-wide configuration (e.g. /etc, the kernel, initrd, systemd). Other tools like Home Manager may also have their own profiles. By default, a user's active profile is stored at ~/.nix-profile:
$ ls -l ~/.nix-profile
Nix Manual: Profiles
Nix Pills - The first profile
Generation
Nix An instance of a user environment. When a user makes any change to their environment, such as installing or removing packages, a new generation of the environment is created instead of modifying the environment in-place. This ensures that updates are atomic and the user can easily roll-back to any previous generation if something goes wrong. The current generation is a user's currently active user profile. Nix Manual: Profiles
Derivation Nix A Nix expression which describes a build action. Derivations are analogous to package definitions in other package managers. High-level derivations, such as the ones describing packages in Nixpkgs, get evaluated into low-level derivations (called store derivations), for instance by using the nix-instantiate command. nix-store --realise runs the build commands described in the low-level derivation, producing one or more output paths. nix-build is a user-friendly wrapper for the previous two commands. Nix Manual: Glossary - Derivation
Nix Manual: Derivation
$ ls -ld /nix/store/*-firefox-9*/
rec { } Nix expressions The { } block contains "mutually recursive" attributes, which means they can refer to each other. Nix Manual: Syntax and semantics: Recursive sets
NixPkgs Release Notes
