NixOS Installation Guide
Revision as of 01:51, 26 November 2017 by imported>Samueldr (Adds stub booting section)
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
NixOS can be installed on an increasing variety of hardware, including the usual x86-type hardware.
  1. A regular (Intel or AMD) desktop computer, laptop, or physically accessible server can follow the instructions in this page
  2. SBCs, like the Raspberry Pis, and other ARM boards can follow the instructions at NixOS on ARM
  3. Cloud and remote servers will find various instructions at NixOS friendly hosters
Installation method
  1. The classic way, booting from the installation media (described in this page)
Making the installation media
"Burning" to USB drive
From Linux
  2. Burn with: cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd also works.
From macOS
Template:Outdated:inline
  3. Burn with: sudo dd if=path_to_nixos.iso of=/dev/rdiskX bs=64k
Note: Use rdisk instead of disk, this makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
You could use Disk Utility to write the image but then you'd need to convert it first to a compatible format somehow.
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
