NixOS Installation Guide
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
NixOS can be installed on an increasing variety of hardware, including the usual x86-type hardware.
- A regular (Intel or AMD) desktop computer, laptop, or physically accessible server can follow the instructions in this page
- SBCs, like the Raspberry Pis, and other ARM boards can follow the instructions at NixOS on ARM
- Cloud and remote servers will find various instructions at NixOS friendly hosters
Installation method
- The classic way, booting from the installation media (described in this page)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblk
orfdisk -l
. Replace/dev/sdX
with the proper device in the following steps. - Burn with:
cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd
also works.
From macOS
diskutil list
, let's saydiskX
. - Unmount with
diskutil unmountDisk diskX
. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/rdiskX bs=64k
rdisk
instead of disk
, this makes a large speed difference. You can check the write speed with iostat 2
in another terminal.You could use Disk Utility to write the image but then you'd need to convert it first to a compatible format somehow.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
- Brand servers may require extra kernel modules be included into initrd (boot.initrd.extraKernelModules in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
