Help:Templates
From NixOS Wiki
Revision as of 19:51, 5 June 2025 by DoggoBit (talk | contribs)
The wiki provides templates for common tasks.
Those templates can range from simple to complex, being almost invisible to the end-user to provide a complete harmonized template between articles.
In addition to the visual aspect, using some templates will automatically file and categorize articles in ways indispensable to the end-users.
Available templates
These templates are meant to be used across the whole wiki.
There are other section-specific templates, and templates for internal use available too.
Status notices
Status notices are essential to our own housekeeping, as well as making the reader aware of certain caveats related to articles. They generally prompt the reader to contribute, edit, navigate or otherwise exercise caution when reading a certain article or section.
Template Example Notes
{{disambiguation}}
Disambiguation: Not to be confused with Help:Help.
Sometimes a single page can refer to more than one thing; use this template to link to the other pages
{{merge}}
This article or section is a candidate for merging with Help:Help. Further information may be found in the relevant discussion page.
If two pages are closely related, they might become merge candidates. Use this template to propose a page merger
{{cleanup}}
This article or section needs cleanup. Please edit the article, paying special attention to fixing any formatting issues, inconsistencies, grammar, or phrasing. Make sure to consult the Manual of Style for guidance.
Use this to mark articles or pages that don't follow the Manual of Style
{{low quality}}
This article or section is of low quality. Further information may be found in the related discussion page. Editors that are knowledgeable in this area are encouraged to expand it, otherwise this page could become a candidate for deletion.
Use this template to mark articles that are poorly written, are not substantial enough, or that have big issues and don't meet our standards of quality
{{expansion}}
Use this template to mark articles that contain too little information
{{outdated}}
This article or section is outdated. Further information might be found in the corresponding discussion. Please remove this notice once the information has been updated.
When the information in an article becomes stale, you can use this template to prompt the user to take the information with a grain of salt, and prompt other editors to contribute by updating it.
Notice templates
In general, there are two kinds of notes you can use: big and small notices. Small notices integrate well within the flow of the text, and are meant to convey information that shouldn't distract too much from the reading flow. The table below shows the main small notes available:
{{note}}
Note: This is some important information
To be used for important information that shouldn't break the reading flow.
{{aside}}
Sidenote: This information is not that important.
To be used for related information that is not essential for the main body of an article.
Big notices are purposefully disruptive, and are meant to capture a reader's attention. Use these to convey information that should be read first, especially when the user is glancing over a page without reading it in detail.
{{tip}}
Tip: Something you might easily miss
To be used for quick reminders that users often miss.
{{info}}
Note: Some key information you should be aware of
To be used for bringing key information to the reader's attention.
{{warning}}
Warning: This information is highly important.
To be used for marking potentially dangerous, disruptive or destructive actions.
{{security Warning}}
Security information: This information is paramount.
To be used for marking key security concerns.
Prefab tips
Common repeated tips in template form.
  • {{evaluate}} reminder to evaluate a NixOS configuration with nixos-rebuild.
  • {{unfree}} a note that a package is unfree, with a link for more help.
Formatting
Misc. prefabs
  • {{app}} for a card with details about an application.
  • {{man}} to refer to a man page (and section).
Code and commands
  • {{commands}} for a list of commands.
  • {{file}} for a formatted code block with a filename header.
  • Prefer the SyntaxHighlight extension with e.g. <syntaxhighlight lang="nix"></syntaxhighlight> otherwise.
These are more raw implementation blocks. They are not recommended for broad use.
Nix, Nixpkgs and NixOS
These helpers link to specific project parts.
Nix
Nixpkgs
NixOS
Page construction
Templates helping in building pages with common forms.
Visual Guidelines
The icons used are from Breeze, the default icon set of KDE.
Since the icons from Breeze are used, the colours from HIG, which is the Breeze Color Palette are used.
Sometimes, there isn't an icon in the Breeze theme that can be used for the purpose. In this case, alternative free and open source icons can be used. Once a stand-in is used, someone with the necessary skills can create the needed icon in the breeze style.
See also
