Configuration
Hard drives
services.udev.extraRules =
  in mkRules ([( mkRule [
    ''ACTION=="add|change"''
    ''SUBSYSTEM=="block"''
    ''KERNEL=="sd[a-z]"''
Suspend hooks
    script = ''
Hibernation
Hibernation requires a configured swap device. See installation instructions on how to create a swap partition. An example configuration could look like this:
swapDevices = [
    device = "/dev/hda7";
boot.resumeDevice = "/dev/hda7";
Please note that encrypted swap devices or swap files are not yet supported for hibernation. Test and use hibernation with following command:
systemctl hibernate
Tips and tricks
  HibernateDelaySec=1h
Or, to disable suspend entirely, consider a configuration like this:
  AllowSuspend=no
  AllowHibernation=no
  AllowHybridSleep=no
  AllowSuspendThenHibernate=no
Troubleshooting
services.udev.extraRules = ''
$ cat /proc/acpi/wakeup
GP30	  S4	*disabled
PT27	  S4	*disabled
PT28	  S4	*disabled
0x1987
0x5013
See also
External resources
