Power Management
Configuration
Hard drives
services.udev.extraRules =
in mkRules ([( mkRule [
''ACTION=="add|change"''
''SUBSYSTEM=="block"''
''KERNEL=="sd[a-z]"''
Suspend hooks
script = ''
Hibernation
Systemd (systemd-sleep and systemd-hibernate-resume) automates finding locating the resume data[1][2] if you have systemd in initrd enabled (boot.initrd.systemd.enable, on by default)[3]. Otherwise you must set boot.resumeDevice and optionally the resume_offset kernel parameter[4].
Therefore, an example configuration could look like this:
# I'm hibernating into a logical volume that's also under LUKS. Pretty cool, right?
swapDevices = [
device = "/dev/VG/SWAP";
Derived from a system with the following output from swapon -s :
Filename Type Size Used Priority
/dev/dm-7 partition 67108860 00
/dev/zram0 partition 32881148 032767
Test and use hibernation with the following command:
$ systemctl hibernate
Tips and tricks
Hibernate after specified time
systemd.sleep.settings.Sleep = {
HibernateDelaySec = "1h";
Disable all sleep functionality
Some desktop environment and display manager combinations might attempt to put your machine to sleep as default behavior (i.e. SDDM and KDE Plasma 6 under Wayland). If this is not what you want, you can define the following to block any service attempting to put your machine to sleep via systemd:
AllowHibernation = "no";
AllowHybridSleep = "no";
AllowSuspend = "no";
AllowSuspendThenHibernate = "no";
Troubleshooting
services.udev.extraRules = ''
$ cat /proc/acpi/wakeup
Device S-state Status Sysfs node
GP12 S4 *enabled pci:0000:00:07.1
GP13 S4 *disabled pci:0000:00:08.1
XHC0 S4 *enabled pci:0000:0a:00.3
GP30 S4 *disabled
PT27 S4 *disabled
PT28 S4 *disabled
PT29 S4 *disabled pci:0000:03:09.0
$ echo GPP0 | sudo tee /proc/acpi/wakeup
0x1987
0x5013
Suspend blocked by pre-sleep.service
Sometimes, the system appears to suspend (Wi-Fi turns off, screen locks), but the hardware does not actually suspend, and all subsequent systemctl suspend or systemctl reboot commands are met with:
# systemctl suspend
Call to Suspend failed: Action suspend already in progress, refusing requested suspend operation.
# systemctl reboot
Call to Reboot failed: Action suspend already in progress, refusing requested reboot operation.
If directly telling the kernel to suspend as root works:
# echo mem > /sys/power/state
Then a long-running pre-sleep.service might be hanging the sleep. This can be verified with systemctl list-jobs:
# systemctl list-jobs
JOB UNIT TYPE STATE
12144 suspend.target start waiting
12149 pre-sleep.service start running
12145 systemd-suspend.service start waiting
12268 post-resume.target start waiting
12148 sleep.target start waiting
12269 post-resume.service start waiting
Here, the pre-sleep.service is blocking and halting suspend. To see why, we can use systemctl cat pre-sleep.service:
# systemctl cat pre-sleep.service
# /etc/systemd/system/pre-sleep.service
[Unit]
Before=sleep.target
Description=Pre-Sleep Actions
[Service]
# <... Omitted Environment directives PATH, LOCALE_ARCHIVE, TZDIR ...>
ExecStart=/nix/store/yzf7cpiqzq49san2frijxsh160zjy6fp-unit-script-pre-sleep-start/bin/pre-sleep-start
Type=oneshot
[Install]
WantedBy=sleep.target
In this case, the pre-sleep-start script referenced by ExecStart contained directives installed by the Displaylink package, that contained a flush operation which hung the suspend action. Starting dlm.service or running sudo DisplayLinkManager unblocks the script and made suspend work normally.
Cancelling an existing suspend action
An existing suspend operation that is hung may be interrupted using systemctl cancel in case reboots or internet access is needed.
See also
External resources
References
- ↑ https://www.freedesktop.org/software/systemd/man/latest/systemd-hibernate-resume.html#
- ↑ https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Pass_hibernate_location_to_initramfs
- ↑ https://github.com/nix-community/disko/issues/651#issuecomment-2381644055
- ↑ https://docs.kernel.org/power/swsusp.html
