Power Management
From NixOS Wiki
Revision as of 10:18, 31 July 2025 by Hustlerone (talk | contribs) (remove some whitespace and fix typo)
Configuration
Hard drives
services.udev.extraRules =
  in mkRules ([( mkRule [
    ''ACTION=="add|change"''
    ''SUBSYSTEM=="block"''
    ''KERNEL=="sd[a-z]"''
Suspend hooks
    script = ''
Hibernation
Therefore, an example configuration could look like this:
  I'm hibernating into a logical volume that's also under LUKS. Pretty cool, right?
swapDevices = [
    device = "/dev/VG/SWAP";
Derived from a system with the following output from swapon -s :
Filename                                Type            Size           Used             Priority
/dev/dm-7                               partition       67108860       00
/dev/zram0                              partition       32881148       032767
Test and use hibernation with the following command:
systemctl hibernate
Tips and tricks
  HibernateDelaySec=1h
Or, to disable suspend entirely, consider a configuration like this:
  AllowSuspend=no
  AllowHibernation=no
  AllowHybridSleep=no
  AllowSuspendThenHibernate=no
Troubleshooting
services.udev.extraRules = ''
$ cat /proc/acpi/wakeup
GP30	  S4	*disabled
PT27	  S4	*disabled
PT28	  S4	*disabled
0x1987
0x5013
See also
External resources
