Uninterruptible power supply
Revision as of 14:50, 6 October 2025 by Tie-ling (talk | contribs) (init)
Compatible Hardware
Components of NUT Software
Configuration files in use
  • upsmon.conf, connect to upsd, power.ups.upsmon.monitor section;
  • upsmon.conf, set how upsmon should react to status changes,
 power.ups.upsmon.settings section
  • delayed UPS shutdown systemd unit, to make Restore Power on AC
 Return BIOS option functional,
 systemd.services.nut-delayed-ups-shutdown section
