Uninterruptible power supply
Compatible Hardware
Components of NUT Software
Configuration files in use
Declare UPS units
Corresponds to file ups.conf
  power.ups = {
    mode = "standalone";
    ups."UPS-1" = {
      description = "Eaton Ellipse ECO 650 with 12V 7Ah lead-acid Batt";
      driver = "usbhid-ups";
      port = "auto";
      directives = [
        # wall power returns.
        "offdelay = 60"
        "ondelay = 70"
        "lowbatt = 40"
        # ignore it if the UPS reports a low battery condition
        # without this, system will shutdown only when ups reports lb,
        # not respecting lowbatt option
        "ignorelb"
Declare upsd listening ports
  power.ups = {
    upsd = {
      listen = [
          address = "127.0.0.1";
          port = 3493;
          address = "::1";
          port = 3493;
  power.ups = {
    # declarations. upsd.users
    users."nut-admin" = {
      # A file that contains just the password.
      passwordFile = "/etc/nixos/ups-passwd.txt";
      upsmon = "primary";
Connect upsmon to upsd
  power.ups = {
    upsmon.monitor."UPS-1" = {
      system = "UPS-1@localhost";
      powerValue = 1;
      user = "nut-admin";
      type = "primary";
  power.ups = {
    upsmon.settings = {
      # NOTIFY events.
      # values
      NOTIFYMSG = [
      NOTIFYFLAG = [
        [ "ONLINE" "SYSLOG+WALL" ]
        [ "ONBATT" "SYSLOG+WALL" ]
        [ "LOWBATT" "SYSLOG+WALL" ]
        [ "REPLBATT" "SYSLOG+WALL" ]
        [ "FSD" "SYSLOG+WALL" ]
        [ "SHUTDOWN" "SYSLOG+WALL" ]
        [ "COMMOK" "SYSLOG+WALL" ]
        [ "COMMBAD" "SYSLOG+WALL" ]
        [ "NOCOMM" "SYSLOG+WALL" ]
        [ "NOPARENT" "SYSLOG+WALL" ]
      # battery NOTIFY event
      RBWARNTIME = 216000;
      # unreachable NOTIFY event
      NOCOMMWARNTIME = 300;
      FINALDELAY = 0;
