Uninterruptible power supply
Revision as of 14:51, 6 October 2025 by Tie-ling (talk | contribs) (→Configuration files in use: update formattng)
Compatible Hardware
Components of NUT Software
  • upsmon.conf, connect to upsd, power.ups.upsmon.monitor section;
