Uninterruptible power supply
Revision as of 22:29, 6 October 2025 by Tie-ling (talk | contribs) (fix link to passwd file)
Compatible Hardware
Components of NUT Software
Configuration files in use
Declare UPS units
Corresponds to file ups.conf
  power.ups = {
    mode = "standalone";
    ups."UPS-1" = {
      description = "Eaton Ellipse ECO 650 with 12V 7Ah Batt";
      driver = "usbhid-ups";
      port = "auto";
      directives = [
        # wall power returns.
        "offdelay = 60"
        "ondelay = 70"
        "lowbatt = 40"
Declare upsd listening ports
  power.ups = {
    upsd = {
      listen = [
          address = "127.0.0.1";
          port = 3493;
          address = "::1";
          port = 3493;
  power.ups = {
    # declarations. upsd.users
    users."nut-admin" = {
      passwordFile = "${../resources/ups-passwd.txt}";
      upsmon = "primary";
Connect upsmon to upsd
  power.ups = {
    upsmon.monitor."UPS-1" = {
      system = "UPS-1@localhost";
      powerValue = 1;
      user = "nut-admin";
      type = "primary";
  power.ups = {
    upsmon.settings = {
      # NOTIFY events.
      # values
      NOTIFYMSG = [
      NOTIFYFLAG = [
        [ "ONLINE" "SYSLOG+WALL" ]
        [ "ONBATT" "SYSLOG+WALL" ]
        [ "LOWBATT" "SYSLOG+WALL" ]
        [ "REPLBATT" "SYSLOG+WALL" ]
        [ "FSD" "SYSLOG+WALL" ]
        [ "SHUTDOWN" "SYSLOG+WALL" ]
        [ "COMMOK" "SYSLOG+WALL" ]
        [ "COMMBAD" "SYSLOG+WALL" ]
        [ "NOCOMM" "SYSLOG+WALL" ]
        [ "NOPARENT" "SYSLOG+WALL" ]
      # battery NOTIFY event
      RBWARNTIME = 216000;
      # unreachable NOTIFY event
      NOCOMMWARNTIME = 300;
      FINALDELAY = 0;
Delay UPS Shutdown
During the system shutdown, systemd service unit runs the command upsdrvctl shutdown. This tells the UPS that it is to shut down offdelay seconds later. The system powers down before offdelay seconds have passed. Wall power returns before the UPS shuts down Less than offdelay seconds have passed. The UPS continues it's shutdown process.
After offdelay seconds the UPS shuts down, disconnecting it's outlets. The beeping stops. With some UPS units, there is an audible clunk. An interval of ondelay-offdelay seconds later: After ondelay seconds the UPS turns itself on, and repowers it's outlets. The system BIOS option Restore Power on AC return has hopefully been selected and the system powers up.
    unitConfig = {
      Description = "Initiate delayed UPS shutdown";
      Before = "umount.target";
      DefaultDependencies = false;
    serviceConfig = {
      Type = "oneshot";
      ExecStart = ''${pkgs.bash}/bin/bash -c\
       "${pkgs.util-linux}/bin/logger -t\
        nut-delayed-ups-shutdown 'upsdrvctl shutting down UPS';\
        ${pkgs.nut}/bin/upsdrvctl shutdown"'';
    wantedBy = [ "final.target" ];
