Uninterruptible power supply
Revision as of 03:12, 10 October 2025 by Tie-ling (talk | contribs) (Delay UPS Shutdown: do not use slice)
Compatible Hardware
The end of ConfigExample book says:
Joe's server will still be allright
if power drops off in the night.
  That 8 year old pack
  of battery backup
will easily handle th connection lost
Components of NUT Software
Configuration files in use
Declare UPS units
Corresponds to file ups.conf
  power.ups = {
    mode = "standalone";
    ups."UPS-1" = {
      description = "Eaton Ellipse ECO 650 with 12V 7Ah lead-acid Batt";
      driver = "usbhid-ups";
      port = "auto";
      directives = [
        # wall power returns.
        "offdelay = 60"
        "ondelay = 70"
        "lowbatt = 40"
        # ignore it if the UPS reports a low battery condition
        # without this, system will shutdown only when ups reports lb,
        # not respecting lowbatt option
        "ignorelb"
Declare upsd listening ports
  power.ups = {
    upsd = {
      listen = [
          address = "127.0.0.1";
          port = 3493;
          address = "::1";
          port = 3493;
  power.ups = {
    # declarations. upsd.users
    users."nut-admin" = {
      passwordFile = "${../resources/ups-passwd.txt}";
      upsmon = "primary";
Connect upsmon to upsd
  power.ups = {
    upsmon.monitor."UPS-1" = {
      system = "UPS-1@localhost";
      powerValue = 1;
      user = "nut-admin";
      type = "primary";
  power.ups = {
    upsmon.settings = {
      # NOTIFY events.
      # values
      NOTIFYMSG = [
      NOTIFYFLAG = [
        [ "ONLINE" "SYSLOG+WALL" ]
        [ "ONBATT" "SYSLOG+WALL" ]
        [ "LOWBATT" "SYSLOG+WALL" ]
        [ "REPLBATT" "SYSLOG+WALL" ]
        [ "FSD" "SYSLOG+WALL" ]
        [ "SHUTDOWN" "SYSLOG+WALL" ]
        [ "COMMOK" "SYSLOG+WALL" ]
        [ "COMMBAD" "SYSLOG+WALL" ]
        [ "NOCOMM" "SYSLOG+WALL" ]
        [ "NOPARENT" "SYSLOG+WALL" ]
      # battery NOTIFY event
      RBWARNTIME = 216000;
      # unreachable NOTIFY event
      NOCOMMWARNTIME = 300;
      FINALDELAY = 0;
Delay UPS Shutdown
During the system shutdown, systemd service unit runs the command upsdrvctl shutdown. This tells the UPS that it is to shut down offdelay seconds later. The system powers down before offdelay seconds have passed. Wall power returns before the UPS shuts down. Less than offdelay seconds have now passed. The UPS continues it's shutdown process.
After offdelay seconds the UPS shuts down, disconnecting it's outlets. The beeping stops. With some UPS units, there is an audible clunk. An interval of ondelay minus offdelay seconds later: After ondelay seconds the UPS turns itself on, and repowers it's outlets. The system BIOS option Restore Power on AC return has hopefully been selected and the system powers up.
    environment = config.systemd.services.upsmon.environment;
    description = "Initiate delayed UPS shutdown";
    before = [ "umount.target" ];
    wantedBy = [ "final.target" ];
    serviceConfig = {
      Type = "oneshot";
      # need to use '-u root', or else permission denied
      ExecStart = ''${pkgs.nut}/bin/upsdrvctl -u root shutdown'';
      # must not use slice: if used, upsdrvctl will not run as a late
      # shutdown service
      # Slice = "";
    unitConfig = {
      ConditionPathExists = config.power.ups.upsmon.settings.POWERDOWNFLAG;
      DefaultDependencies = "no";
