Power Management
Revision as of 10:00, 18 January 2026 by Sandro (talk | contribs) (→Hibernation)
Configuration
Hard drives
services.udev.extraRules =
  in mkRules ([( mkRule [
    ''ACTION=="add|change"''
    ''SUBSYSTEM=="block"''
    ''KERNEL=="sd[a-z]"''
Suspend hooks
  script = ''
Hibernation
Therefore, an example configuration could look like this:
// I'm hibernating into a logical volume that's also under LUKS. Pretty cool, right?
swapDevices = [
    device = "/dev/VG/SWAP";
Derived from a system with the following output from swapon -s :
Filename                                Type            Size           Used             Priority
/dev/dm-7                               partition       67108860       00
/dev/zram0                              partition       32881148       032767
Test and use hibernation with the following command:
systemctl hibernate
Tips and tricks
  HibernateDelaySec=1h
Or, to disable suspend entirely, consider a configuration like this:
  AllowSuspend=no
  AllowHibernation=no
  AllowHybridSleep=no
  AllowSuspendThenHibernate=no
Troubleshooting
services.udev.extraRules = ''
$ cat /proc/acpi/wakeup
GP30	  S4	*disabled
PT27	  S4	*disabled
PT28	  S4	*disabled
0x1987
0x5013
Suspend blocked by pre-sleep.service
Sometimes, the system appears to suspend (Wi-Fi turns off, screen locks), but the hardware does not actually suspend, and all subsequent systemctl suspend or systemctl reboot commands are met with:
# systemctl suspend
Call to Suspend failed: Action suspend already in progress, refusing requested suspend operation.
# systemctl reboot
Call to Reboot failed: Action suspend already in progress, refusing requested reboot operation.
If directly telling the kernel to suspend as root works:
# echo mem > /sys/power/state
Then a long-running pre-sleep.service might be hanging the sleep. This can be verified with systemctl list-jobs:
# systemctl list-jobs
JOB   UNIT                    TYPE  STATE
12144 suspend.target          start waiting
12149 pre-sleep.service       start running
12145 systemd-suspend.service start waiting
12268 post-resume.target      start waiting
12148 sleep.target            start waiting
12269 post-resume.service     start waiting
Here, the pre-sleep.service is blocking and halting suspend. To see why, we can use systemctl cat pre-sleep.service:
# systemctl cat pre-sleep.service
# /etc/systemd/system/pre-sleep.service
[Unit]
Before=sleep.target
Description=Pre-Sleep Actions
[Service]
# <... Omitted Environment directives PATH, LOCALE_ARCHIVE, TZDIR ...>
ExecStart=/nix/store/yzf7cpiqzq49san2frijxsh160zjy6fp-unit-script-pre-sleep-start/bin/pre-sleep-start
Type=oneshot
[Install]
WantedBy=sleep.target
In this case, the pre-sleep-start script referenced by ExecStart contained directives installed by the Displaylink package, that contained a flush operation which hung the suspend action. Starting dlm.service or running sudo DisplayLinkManager unblocks the script and made suspend work normally.
Cancelling an existing suspend action
An existing suspend operation that is hung may be interrupted using systemctl cancel in case reboots or internet access is needed.
See also
External resources
