Revision as of 16:30, 21 September 2021 by imported>Nix (order most important items more prominently. better explain profiles and generations)
User Environment
Nix A set of "active" applications. These applications usually exist in the Nix store. A single Nix user may have multiple User Environments. This is an important concept further explored in User Environment. Profiles and generations are closely related.
Nix Manual - Profiles chapter
Nix Manual - nix-env
(User) Profile Nix Most generally, a profile is a link to a generation, and there's a profiles (note the s) folder which collects types of profiles together so that they form lists of generations. In standalone Nix (e.g. on a different Linux distro), it's primary use is user profiles. In NixOS, there's also the system profile, which manages system-wide configuration (e.g. /etc, the kernel, initrd, systemd). Tools like Home Manager also have their own profile (which would also be per-user). The user's active profile is defined in ~/.nix-profile, and is what all nix-env commands would operate on by default.
❯ ls -l ~/.nix-profile
lrwxrwxrwx 1 username users ... /home/username/.nix-profile -> /nix/var/nix/profiles/per-user/username/profile
Nix Manual: Profiles
Generation
Nix A revision of a user environment, newly created every time the system is updated (with old ones being preserved until manually removed). Technically, each generation is simply a link to a specific user environment in the Nix store. This term connotes the cloning and modification of an existing user environment. Nix's environment rollback facilities rely on Generations. The current generation is a user's currently selected user environment, and is generally selected via the active profile (which is just a symlink, normally in /nix/var/nix/profiles/). Nix Manual: Profiles
Derivation Nix A Nix expression which describes a build action. When evaluated, it creates one or more entries in the Nix Store. The nix-instantiate command is the command which creates entries in the Nix Store, while the nix-env and nix-build commands are its user-friendly interface. Nix Manual: Glossary -> Derivation
Nix Manual: Derivation
rec { } Nix expressions The { } block contains "mutually recursive" attributes, which means they can refer to each other. Composing the Hello Package
NixPkgs Release Notes
Template:Bottom whitespace
