Revision as of 14:46, 23 September 2021 by imported>Nix (better define derivations, add output path definition)
User Environment
Nix A set of "active" applications. These applications usually exist in the Nix store. A single Nix user may have multiple User Environments. This is an important concept further explored in User Environment. Profiles and generations are closely related.
Nix Manual - Profiles chapter
Nix Manual - nix-env
(User) Profile Nix Most generally, a profile is a link to a generation, and there's a profiles (note the s) folder which collects types of profiles together so that they form lists of generations. In standalone Nix (e.g. on a different Linux distro), it's primary use is user profiles. In NixOS, there's also the system profile, which manages system-wide configuration (e.g. /etc, the kernel, initrd, systemd). Tools like Home Manager also have their own profile (which would also be per-user). The user's active profile is defined in ~/.nix-profile, and is what all nix-env commands would operate on by default.
❯ ls -l ~/.nix-profile
lrwxrwxrwx 1 username users ... /home/username/.nix-profile -> /nix/var/nix/profiles/per-user/username/profile
Nix Manual: Profiles
Generation
Nix A revision of a user environment, newly created every time the system is updated (with old ones being preserved until manually removed). Technically, each generation is simply a link to a specific user environment in the Nix store. This term connotes the cloning and modification of an existing user environment. Nix's environment rollback facilities rely on Generations. The current generation is a user's currently selected user environment, and is generally selected via the active profile (which is just a symlink, normally in /nix/var/nix/profiles/). Nix Manual: Profiles
Derivation Nix A Nix expression which describes a build action. High-level derivations (like the ones describing packages in Nixpkgs), get evaluated into low-level derivations (called store derivations — because they wind up in the Nix store). nix-instantiate is the command which translates high-level derivations into low-level ones. nix-store --realise can then check and finish their build for the nix store, producing an output path. nix-build is a user-friendly wrapper for the previous commands. Derivations are analogous to package definitions in other tools. Nix Manual: Glossary - Derivation
Nix Manual: Derivation
Output path Nix A store path produced by a derivation. These are generally actual packages, or pieces of them. Nix Manual: Derivation
rec { } Nix expressions The { } block contains "mutually recursive" attributes, which means they can refer to each other. Composing the Hello Package
NixPkgs Release Notes
Template:Bottom whitespace
