G810-led
Appearance
Some Logitech keyboards have LEDs. G810-led is a LED controller for Logitech G213, G410, G413, G512, G513, G610, G810, g815, G910 and GPRO keyboards.
Installation
The program MatMoul/g810-led is provided by the package pkgs.g810-led
To be able to run it, you should add the following udev config :
services.udev = {
packages = [
pkgs.g810-led
After a nixos-rebuild switch
you should be able to run g810-led -a ff0000
Add colors at keyboard plug
Currently, you need to run this command after you plug your keyboard in, with the following udev rule, you are able to run the command automatically after any USB device is plugged in :
services.udev = {
packages = [
pkgs.g810-led
extraRules = ''
ACTION=="add", SUBSYSTEM=="usb", RUN+="${pkgs.g810-led}/bin/g810-led -a 0000ff"
