NixOS Maintenance Quick Reference
A concise command reference for everyday maintenance of a channel-based NixOS system.
System updates
# Show the current NixOS version
nixos-version
# List configured system channels
sudo nix-channel --list
# Update system channels
sudo nix-channel --update
# Preview required builds and downloads
sudo nixos-rebuild dry-build
# Build and activate the updated system
sudo nixos-rebuild switch
# Alternatively, update and rebuild in one step
sudo nixos-rebuild switch --upgrade
Configuration management
# Edit the system configuration
sudo vim /etc/nixos/configuration.nix
# Format the configuration (requires nixfmt)
sudo nixfmt /etc/nixos/configuration.nix
# Validate configuration syntax
nix-instantiate --parse /etc/nixos/configuration.nix >/dev/null
# Evaluate the system configuration
sudo nix-instantiate '<nixpkgs/nixos>' -A system
# Build without activating
sudo nixos-rebuild build
# Build and activate the configuration
System generations
# List system generations
sudo nixos-rebuild list-generations
# Roll back to the previous generation
sudo nixos-rebuild switch --rollback
# Delete specific generations (verify numbers first)
sudo nix-env --profile /nix/var/nix/profiles/system \
  --delete-generations 42 43 44
# Refresh boot entries without rebuilding
sudo /nix/var/nix/profiles/system/bin/switch-to-configuration boot
Garbage collection and storage optimization
# Collect unreachable store paths while preserving generations
sudo nix-collect-garbage
# Delete old profile generations and collect garbage
sudo nix-collect-garbage -d
# Delete generations older than seven days and collect garbage
sudo nix-collect-garbage --delete-older-than 7d
# Deduplicate identical store files using hard links
sudo nix-store --optimise
# Check Nix store disk usage
sudo du -sh /nix/store
Warning: Deleted generations are no longer available for rollback. Refresh boot entries after deleting system generations.
See also
