NixOS Installation Guide
Revision as of 17:58, 12 April 2024 by Dvntsemicolon (talk | contribs) (→NixOS config: added NixOS options search link)
This guide is a companion guide for the official manual. It describes installation of NixOS as a complete operating system. For installation of Nix within an existing operating system, see Nix Installation Guide.
In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
Installation method
Making the installation media
"Burning" to USB drive
From Linux
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
DOS
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Label partitions
This is useful for having multiple setups and makes partitions easier to handle.
  • lsblk
  • sudo mkfs.fat -F 32 /dev/sdX1
  • sudo fatlabel /dev/sdX1 NIXBOOT
  • sudo mkfs.ext4 /dev/sdX2 -L NIXROOT
  • sudo mount /dev/disk/by-label/NIXROOT /mnt
  • sudo mkdir -p /mnt/boot
  • sudo mount /dev/disk/by-label/NIXBOOT /mnt/boot
Swap file
  • sudo dd if=/dev/zero of=/mnt/.swapfile bs=1024 count=2097152 (2GB size)
  • sudo chmod 600 /mnt/.swapfile
  • sudo mkswap /mnt/.swapfile
  • sudo swapon /mnt/.swapfile
NixOS config
  • sudo nixos-generate-config --root /mnt
  • cd /mnt/etc/nixos/
  • sudo vim configuration.nix
Most essential changes:
  • keyboard layout, ie services.xserver.layout
The self-documenting NixOS options can be searched at search.nixos.org/options.
NixOS installation
  • cd /mnt
  • sudo nixos-install
  • nixos-rebuild switch --option substitute false # no downloads
  • nixos-rebuild switch --option binary-caches "" # no downloads
