NixOS Installation Guide
This guide is a companion guide for the official manual. It describes installation of NixOS as a complete operating system. For installation of Nix within an existing operating system, see Nix Installation Guide.
In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
- regular (Intel or AMD) desktop computers, laptops or physically accessible servers, covered on this page
- SBCs (like the Raspberry Pis) and other ARM boards, see NixOS on ARM
- cloud and remote servers, see NixOS friendly hosters
Installation method
- The classic way, booting from the installation media. (Described below.)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblkorfdisk -l. Replace/dev/sdXwith the proper device in the following steps. - Copy to device:
cp nixos-xxx.iso /dev/sdX
From macOS
diskutil list, let's saydiskX. - Unmount with
diskutil unmountDisk diskX. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
rdiskX instead of diskX can makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Using the "Applications" tab at top
left or the launcher bar at bottom, choose a terminal application and from there launch nmtui. This will allow you to 'activate' a (wireless) connection - your local SSIDs should be visible in the list, else you can add a new connection. When the wireless connection is active and you have tested it, it is likely the install app which launched on startup has not detected the new connection. Close down the install app, and reopen it from the launcher bar at the bottom of the screen. This should then find the new connection and proceed.
Partitioning
To partition the persistent storage run sudo fdisk /dev/diskX and follow instructions for DOS or (U)EFI.
DOS
- o (dos disk label)
- n new
- p primary (4 primary in total)
- 1 (partition number [1/4])
- 2048 first sector (alignment for performance)
- +500M last sector (boot sector size)
- rm signature (Y), if ex. => warning of overwriting existing system, could use wipefs
- n
- p
- 2
- default (fill up partition)
- w (write)
UEFI
- g (gpt disk label)
- n
- 1 (partition number [1/128])
- 2048 first sector
- t
- 1 (EFI System)
- n
- 2
- w (write)
Label partitions
This is useful for having multiple setups and makes partitions easier to handle.
- lsblk
- sudo mkfs.fat -F 32 /dev/sdX1
- sudo fatlabel /dev/sdX1 NIXBOOT
- sudo mkfs.ext4 /dev/sdX2 -L NIXROOT
- sudo mount /dev/disk/by-label/NIXROOT /mnt
- sudo mkdir -p /mnt/boot
- sudo mount /dev/disk/by-label/NIXBOOT /mnt/boot
Swap file
- sudo dd if=/dev/zero of=/mnt/.swapfile bs=1024 count=2097152 (2GB size)
- sudo chmod 600 /mnt/.swapfile
- sudo mkswap /mnt/.swapfile
- sudo swapon /mnt/.swapfile
NixOS config
- sudo nixos-generate-config --root /mnt
- cd /mnt/etc/nixos/
- sudo vim configuration.nix
Most essential changes:
- keyboard layout, ie
services.xserver.layout users.users.userwith adding entryinitialPassword = "pw123";- networking (wifi), see below for fix if it breaks
boot.loader.grub.device = "/dev/sda"; #or "nodev" for efi only- install editor to edit the configuration
- change hardware config to use labels
The self-documenting NixOS options can be searched with [search.nixos.org/options NixOS options search].
NixOS installation
- cd /mnt
- sudo nixos-install
- nixos-rebuild switch --option substitute false # no downloads
- nixos-rebuild switch --option binary-caches "" # no downloads
- wpa_supplicant flags to connect to wifi
- Brand servers may require extra kernel modules be included into initrd (boot.initrd.extraKernelModules in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
