NixOS安装指南
Revision as of 12:45, 23 February 2025 by Mayer (talk | contribs) (Created page with "这份指南是对[https://nixos.org/nixos/manual/index.html#ch-installation 官方手册]的一份参考指南. 它讲述了把NixOS作为完整操作系统的安装过程. For installation of Nix within an existing operating system,为了在一个已存在的操作系统内安装Nix, 请见Nix安装指南.")
这份指南是对官方手册的一份参考指南. 它讲述了把NixOS作为完整操作系统的安装过程. For installation of Nix within an existing operating system,为了在一个已存在的操作系统内安装Nix, 请见Nix安装指南.
In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
安装目标
Installation method
Making the installation media
"Burning" to USB drive
From Linux
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
DOS
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
Most essential changes:
NixOS installation
$ cd /mnt
$ sudo nixos-install
