NixOS安装指南
除了讲述官方手册上的步骤, 它还提供了用于常见使用场景的已知良好指导.When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.当官方手册和这份指南之间出现矛盾时, 以官方手册中描述的情况为准.
安装目标
- regular (Intel or AMD) desktop computers, laptops or physically accessible servers, covered on this page
- SBCs (like the Raspberry Pis) and other ARM boards, see NixOS on ARM
- cloud and remote servers, see NixOS friendly hosters
Installation method
- The classic way, booting from the installation media. (Described below.)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblk
orfdisk -l
. Replace/dev/sdX
with the proper device in the following steps. - Copy to device:
cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd if=nixos.iso of=/dev/sdX bs=4M status=progress conv=fdatasync
also works.
From macOS
diskutil list
, let's saydiskX
. - Unmount with
diskutil unmountDisk diskX
. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Network Manager is installed on the graphical ISO, meaning that it is possible to use nmtui
on the command line to connect to a network.
Using the "Applications" tab at top
left or the launcher bar at bottom, choose a terminal application and from there launch nmtui
. This will allow you to 'activate' a (wireless) connection - your local SSIDs should be visible in the list, else you can add a new connection. When the wireless connection is active and you have tested it, it is likely the install app which launched on startup has not detected the new connection. Close down the install app, and reopen it from the launcher bar at the bottom of the screen. This should then find the new connection and proceed.
On the minimal ISO, or if you are more familiar with wpa_supplicant
then you can also run wpa_passphrase ESSID | sudo tee /etc/wpa_supplicant.conf
, then enter your password and systemctl restart wpa_supplicant
Partitioning
To partition the persistent storage run sudo fdisk /dev/diskX
and follow instructions for DOS or (U)EFI.
DOS
- o (dos disk label)
- n new
- p primary (4 primary in total)
- 1 (partition number [1/4])
- 2048 first sector (alignment for performance)
- +500M last sector (boot sector size)
- rm signature (Y), if ex. => warning of overwriting existing system, could use wipefs
- n
- p
- 2
- default (fill up partition)
- w (write)
UEFI
- g (gpt disk label)
- n
- 1 (partition number [1/128])
- 2048 first sector
- t
- 1 (EFI System)
- n
- 2
- w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
- keyboard layout, ie
services.xserver.xkb.layout
users.users.user
with adding entryinitialPassword = "pw123";
- networking (wifi), see below for fix if it breaks
boot.loader.grub.device = "/dev/sda"; #or "nodev" for efi only
- install editor to edit the configuration
- change hardware config to use labels
NixOS installation
$ cd /mnt
$ sudo nixos-install
passwd
to change user password.
- wpa_supplicant flags to connect to wifi
- Brand servers may require extra kernel modules be included into initrd (
boot.initrd.extraKernelModules
in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
