NixOS安装指南
Revision as of 12:57, 23 February 2025 by Mayer (talk | contribs) (Created page with "NixOS可以安装在越来越多种类的硬件上:")
除了讲述官方手册上的步骤, 它还提供了用于常见使用场景的已知良好指导.When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.当官方手册和这份指南之间出现矛盾时, 以官方手册中描述的情况为准.
Use this guide as a step-by-step guide, choices will be presented, use only the selected section, and continue at the section it tells you to at the end. 把这份指南当作逐步操作指南使用. 出现不同选择时, 只使用选定的部分, 并在这部分的结尾按照它的指示前进.
安装目标
Installation method
Making the installation media
"Burning" to USB drive
From Linux
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
DOS
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
Most essential changes:
NixOS installation
$ cd /mnt
$ sudo nixos-install
