NixOS安装指南
除了讲述官方手册上的步骤, 它还提供了用于常见使用场景的已知良好指导.When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.当官方手册和这份指南之间出现矛盾时, 以官方手册中描述的情况为准.
Use this guide as a step-by-step guide, choices will be presented, use only the selected section, and continue at the section it tells you to at the end. 把这份指南当作逐步操作指南使用. 出现不同选择时, 只使用选定的部分, 并在这部分的结尾按照它的指示前进.
安装目标
NixOS可以安装在越来越多种类的硬件上:
- 常规(Intel或AMD)台式机, 笔记本电脑, 或是物理可访问的服务器, 该页面包含了它们
- 单板计算机(如树莓派)和其他ARM主板, 见 NixOS on ARM
- 云服务器和远程服务器, 见 NixOS friendly hosters
安装方式
- 传统方式, 通过安装媒介启动.(会在下面讲述.)
- 通过已存在的Linux安装启动媒介
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblkorfdisk -l. Replace/dev/sdXwith the proper device in the following steps. - Copy to device:
cp nixos-xxx.iso /dev/sdX
From macOS
diskutil list, let's saydiskX. - Unmount with
diskutil unmountDisk diskX. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
rdiskX instead of diskX can makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Using the "Applications" tab at top
left or the launcher bar at bottom, choose a terminal application and from there launch nmtui. This will allow you to 'activate' a (wireless) connection - your local SSIDs should be visible in the list, else you can add a new connection. When the wireless connection is active and you have tested it, it is likely the install app which launched on startup has not detected the new connection. Close down the install app, and reopen it from the launcher bar at the bottom of the screen. This should then find the new connection and proceed.
Partitioning
To partition the persistent storage run sudo fdisk /dev/diskX and follow instructions for DOS or (U)EFI.
DOS
- o (dos disk label)
- n new
- p primary (4 primary in total)
- 1 (partition number [1/4])
- 2048 first sector (alignment for performance)
- +500M last sector (boot sector size)
- rm signature (Y), if ex. => warning of overwriting existing system, could use wipefs
- n
- p
- 2
- default (fill up partition)
- w (write)
UEFI
- g (gpt disk label)
- n
- 1 (partition number [1/128])
- 2048 first sector
- t
- 1 (EFI System)
- n
- 2
- w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
- keyboard layout, ie
services.xserver.xkb.layout users.users.userwith adding entryinitialPassword = "pw123";- networking (wifi), see below for fix if it breaks
boot.loader.grub.device = "/dev/sda"; #or "nodev" for efi only- install editor to edit the configuration
- change hardware config to use labels
NixOS installation
$ cd /mnt
$ sudo nixos-install
passwd to change user password.
- wpa_supplicant flags to connect to wifi
- Brand servers may require extra kernel modules be included into initrd (
boot.initrd.extraKernelModulesin configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
