NixOS安装指南
安装目标
NixOS可以安装在越来越多种类的硬件上:
- 常规(Intel或AMD)台式机, 笔记本电脑, 或是物理可访问的服务器, 该页面包含了它们
- 单板计算机(如树莓派)和其他ARM开发板, 见 NixOS on ARM
- 云服务器和远程服务器, 见 NixOS friendly hosters
安装方式
- 传统方式, 通过安装媒介启动.(会在下面讲述.)
- 通过已存在的Linux安装启动媒介
制作安装媒介
"刻录"到USB驱动器
在Linux上
- 通过
lsblk
或fdisk -l
找到正确的设备. 在接下来的步骤中, 把/dev/sdX
替换为正确的设备. - 复制到设备:
cp nixos-xxx.iso /dev/sdX
也可通过 dd if=nixos.iso of=/dev/sdX bs=4M status=progress conv=fdatasync
写入硬盘镜像
在macOS上
- Find the right device with
diskutil list
, let's saydiskX
. - Unmount with
diskutil unmountDisk diskX
. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
在Windows上
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
可选的安装媒介指导
之前的方式是制作USB安装媒介的受支持方式.
启动安装媒介
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Network Manager is installed on the graphical ISO, meaning that it is possible to use nmtui
on the command line to connect to a network.
Using the "Applications" tab at top
left or the launcher bar at bottom, choose a terminal application and from there launch nmtui
. This will allow you to 'activate' a (wireless) connection - your local SSIDs should be visible in the list, else you can add a new connection. When the wireless connection is active and you have tested it, it is likely the install app which launched on startup has not detected the new connection. Close down the install app, and reopen it from the launcher bar at the bottom of the screen. This should then find the new connection and proceed.
On the minimal ISO, or if you are more familiar with wpa_supplicant
then you can also run wpa_passphrase ESSID | sudo tee /etc/wpa_supplicant.conf
, then enter your password and systemctl restart wpa_supplicant
Partitioning
To partition the persistent storage run sudo fdisk /dev/diskX
and follow instructions for DOS or (U)EFI.
DOS
- o (dos disk label)
- n new
- p primary (4 primary in total)
- 1 (partition number [1/4])
- 2048 first sector (alignment for performance)
- +500M last sector (boot sector size)
- rm signature (Y), if ex. => warning of overwriting existing system, could use wipefs
- n
- p
- 2
- default (fill up partition)
- w (write)
UEFI
- g (gpt disk label)
- n
- 1 (partition number [1/128])
- 2048 first sector
- t
- 1 (EFI System)
- n
- 2
- w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
- keyboard layout, ie
services.xserver.xkb.layout
users.users.user
with adding entryinitialPassword = "pw123";
- networking (wifi), see below for fix if it breaks
boot.loader.grub.device = "/dev/sda"; #or "nodev" for efi only
- install editor to edit the configuration
- change hardware config to use labels
NixOS installation
$ cd /mnt
$ sudo nixos-install
passwd
to change user password.
- wpa_supplicant flags to connect to wifi
- Brand servers may require extra kernel modules be included into initrd (
boot.initrd.extraKernelModules
in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
