NixOS安装指南
Revision as of 13:42, 23 February 2025 by Mayer (talk | contribs)
安装目标
NixOS可以安装在越来越多种类的硬件上:
安装方式
  1. 传统方式, 通过安装媒介启动.(会在下面讲述.)
  2. 通过已存在的Linux安装启动媒介
制作安装媒介
"刻录"到USB驱动器
在Linux上
在macOS上
在Windows上
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
可选的安装媒介指导
之前的方式是制作USB安装媒介的受支持方式.
启动安装媒介
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
DOS
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
Most essential changes:
NixOS installation
$ cd /mnt
$ sudo nixos-install
