NixOS Installation Guide
Revision as of 13:44, 23 February 2025 by Mayer (talk | contribs)
This guide is a companion guide for the official manual. It describes installation of NixOS as a complete operating system. For installation of Nix within an existing operating system, see Nix Installation Guide.
In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
Installation method
Making the installation media
"Burning" to USB drive
From Linux
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
DOS
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Label partitions
$ lsblk
$ sudo mkdir -p /mnt/boot
Swap file
$ sudo mkswap /mnt/.swapfile
$ sudo swapon /mnt/.swapfile
NixOS config
$ cd /mnt/etc/nixos/
$ sudo vim configuration.nix
Most essential changes:
NixOS installation
$ cd /mnt
$ sudo nixos-install
after installation: Run passwd to change user password. if internet broke/breaks, try one of the following:
