NixOS Installation Guide
From NixOS Wiki
Revision as of 21:10, 14 January 2019 by imported>Janat08
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
NixOS can be installed on an increasing variety of hardware, including the usual x86-type hardware.
  1. A regular (Intel or AMD) desktop computer, laptop, or physically accessible server can follow the instructions in this page
  2. SBCs, like the Raspberry Pis, and other ARM boards can follow the instructions at NixOS on ARM
  3. Cloud and remote servers will find various instructions at NixOS friendly hosters
Installation method
  1. The classic way, booting from the installation media (described in this page)
Making the installation media
"Burning" to USB drive
From Linux
  2. Burn with: cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd also works.
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
If you can't wire internet to computer and wireless isn't working you may use smartphone's tethering capability to share internet, it doesn't appear to require drivers and therefore is likely to work.
Wireless
Network Manager is installed, meaning that it is possible to use nmtui on the command line to connect to a network.
If you are more familiar with wpa_supplicant then you can also run wpa_passphrase ESSID >/etc/wpa_supplicant.conf and systemctl restart wpa_supplicant.
