NixOS Installation Guide
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
NixOS can be installed on an increasing variety of hardware, including the usual x86-type hardware.
- A regular (Intel or AMD) desktop computer, laptop, or physically accessible server can follow the instructions in this page
- SBCs, like the Raspberry Pis, and other ARM boards can follow the instructions at NixOS on ARM
- Cloud and remote servers will find various instructions at NixOS friendly hosters
Installation method
- The classic way, booting from the installation media (described in this page)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblkorfdisk -l. Replace/dev/sdXwith the proper device in the following steps. - Burn with:
cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd also works.
From macOS
diskutil list, let's saydiskX. - Unmount with
diskutil unmountDisk diskX. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
rdiskX instead of diskX can makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
If you can't wire internet to computer and wireless isn't working you may use smartphone's tethering capability to share internet. Depending on your smartphones capabilities, only stock kernel drivers may be required which can help providing a working network connection.
Wireless
Network Manager is installed, meaning that it is possible to use nmtui on the command line to connect to a network.
If you are more familiar with wpa_supplicant then you can also run wpa_passphrase ESSID >/etc/wpa_supplicant.conf and systemctl restart wpa_supplicant.
- Brand servers may require extra kernel modules be included into initrd (boot.initrd.extraKernelModules in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
