NixOS Installation Guide
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
- regular (Intel or AMD) desktop computers, laptops or physically accessible servers, covered on this page
- SBCs (like the Raspberry Pis) and other ARM boards, see NixOS on ARM
- cloud and remote servers, see NixOS friendly hosters
Installation method
- The classic way, booting from the installation media. (Described below.)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblk
orfdisk -l
. Replace/dev/sdX
with the proper device in the following steps. - Burn with:
cp nixos-xxx.iso /dev/sdX
Writing the disk image with dd
also works.
From macOS
diskutil list
, let's saydiskX
. - Unmount with
diskutil unmountDisk diskX
. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
rdiskX
instead of diskX
can makes a large speed difference. You can check the write speed with iostat 2
in another terminal.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Network Manager is installed, meaning that it is possible to use nmtui
on the command line to connect to a network.
If you are more familiar with wpa_supplicant
then you can also run wpa_passphrase ESSID >/etc/wpa_supplicant.conf
and systemctl restart wpa_supplicant
- Brand servers may require extra kernel modules be included into initrd (boot.initrd.extraKernelModules in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
