NixOS Installation Guide
Revision as of 06:34, 9 May 2022 by imported>Rtpg (Fix up formatting of list)
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
Installation method
Making the installation media
"Burning" to USB drive
From Linux
  2. Burn with: cp nixos-xxx.iso /dev/sdX
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
DOS
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Label partitions
This is useful for having multiple setups and makes partitions easier to handle.
  • lsblk
  • sudo mkfs.fat -F 32 /dev/sdX1
  • sudo fatlabel /dev/sdX1 NIXBOOT
  • sudo mkfs.ext4 /dev/sdX2 -L NIXROOT
  • sudo mount /dev/disk/by-label/NIXROOT /mnt
  • sudo mkdir -p /mnt/boot
  • sudo mount /dev/disk/by-label/NIXBOOT /mnt/boot
Swap file (only simple on uefi)
  • sudo dd if=/dev/zero of=/mnt/.swapfile bs=1024 count=2097152 (2GB size)
  • sudo chmod 600 /mnt/.swapfile
  • sudo mkswap /mnt/.swapfile
  • sudo swapon /mnt/.swapfile
NixOS config
  • sudo nixos-generate-config --root /mnt
  • cd /mnt/etc/nixos/
  • sudo vim configuration.nix
Most essential changes:
  • keyboard layout, ie services.xserver.layout
NixOS installation
  • cd /mnt
  • sudo nixos-install
  • nixos-rebuild switch --option substitute false # no downloads
  • nixos-rebuild switch --option binary-caches "" # no downloads
