NixOS Installation Guide
This guide is a companion guide for the official manual. In addition to describing the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
- regular (Intel or AMD) desktop computers, laptops or physically accessible servers, covered on this page
- SBCs (like the Raspberry Pis) and other ARM boards, see NixOS on ARM
- cloud and remote servers, see NixOS friendly hosters
Installation method
- The classic way, booting from the installation media. (Described below.)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblkorfdisk -l. Replace/dev/sdXwith the proper device in the following steps. - Burn with:
cp nixos-xxx.iso /dev/sdX
From macOS
diskutil list, let's saydiskX. - Unmount with
diskutil unmountDisk diskX. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
rdiskX instead of diskX can makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
To partition the persistent storage run sudo fdisk /dev/diskX and follow instructions for DOS or (U)EFI.
DOS
- o (dos disk label)
- n new
- p primary (4 primary in total)
- 1 (partition number [1/4])
- 2048 first sector (alignment for performance)
- +500M last sector (boot sector size)
- rm signature (Y), if ex. => warning of overwriting existing system, could use wipefs
- n
- p
- 2
- default (fill up partition)
- w (write)
UEFI
- g (gpt disk label)
- n
- 1 (partition number [1/128])
- 2048 first sector
- t
- 1 (EFI System)
- n
- 2
- w (write)
Label partitions
This is useful for having multiple setups and makes partitions easier to handle.
- lsblk
- sudo mkfs.fat -F 32 /dev/sdX1
- sudo fatlabel /dev/sdX1 NIXBOOT
- sudo mkfs.ext4 /dev/sdX2 -L NIXROOT
- sudo mount /dev/disk/by-label/NIXROOT /mnt
- sudo mkdir -p /mnt/boot
- sudo mount /dev/disk/by-label/NIXBOOT /mnt/boot
Swap file
- sudo dd if=/dev/zero of=/mnt/.swapfile bs=1024 count=2097152 (2GB size)
- sudo chmod 600 /mnt/.swapfile
- sudo mkswap /mnt/.swapfile
- sudo swapon /mnt/.swapfile
NixOS config
- sudo nixos-generate-config --root /mnt
- cd /mnt/etc/nixos/
- sudo vim configuration.nix
Most essential changes:
- keyboard layout, ie
services.xserver.layout users.users.userwith adding entryinitialPassword = "pw123";- networking (wifi), see below for fix if it breaks
boot.loader.grub.device = "/dev/sda"; #or "nodev" for efi only- install editor to edit the configuration
- change hardware config to use labels
NixOS installation
- cd /mnt
- sudo nixos-install
- nixos-rebuild switch --option substitute false # no downloads
- nixos-rebuild switch --option binary-caches "" # no downloads
- wpa_supplicant flags to connect to wifi
- Brand servers may require extra kernel modules be included into initrd (boot.initrd.extraKernelModules in configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
