Power Management
Revision as of 23:45, 22 August 2023 by imported>Lelgenio (Add workaround for systems that immediatly wakeup after beign suspended)
Suspend
Suspend hooks
It is also possible, to use the post-resume target directly to make a service. Refer to the Systemd Services article for details about writing systemd services for NixOS.
    script = ''
Troubleshooting
System Immediately wakes up from suspend
Particularly in some gigabyte motherboards with NVMe drives, the system may immediately wake up from being suspended. This can be worked around by disabling the wakeup triggers for the offending components:
If you don't need your system to wakeup via PCIe components you can simply disable it for all without needing to search for what component is causing problems.
services.udev.extraRules = ''
Solution 2: Disabling a common NVMe interface
Solution 3: Disabling a single device's wakeup triggers
If you wish to be more granular in what components should no longer be able to wakeup your system you can manually search what component is causing the wakeup events.
$ cat /proc/acpi/wakeup
GP30	  S4	*disabled
PT27	  S4	*disabled
PT28	  S4	*disabled
You can temporarily toggle a device by sending it's "Device" collumn back into `/proc/acpi/wakeup`
0x1987
0x5013
External resources
