Power Management
Revision as of 13:26, 20 October 2023 by imported>Skylark (Drop a redlink, add See also: Laptop which overlaps with this article)
Suspend
Suspend hooks
    script = ''
Troubleshooting
services.udev.extraRules = ''
$ cat /proc/acpi/wakeup
GP30	  S4	*disabled
PT27	  S4	*disabled
PT28	  S4	*disabled
0x1987
0x5013
See also
External resources
