NixOS Installation Guide
From NixOS Wiki
Revision as of 13:32, 15 June 2025 by Neic (talk | contribs) (fix bug in partition label)
This guide serves as a companion guide for the official manual. It describes installation of NixOS as a complete operating system. For instructions on installing Nix within an existing operating system, refer to the Nix Installation Guide.
In addition to covering the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
Installation method
Making the installation media
"Burning" to USB drive
From Linux
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
Legacy Boot (MBR)
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Format partitions
# mkdir -p /mnt/boot
NixOS configuration
Most essential changes:
Swap file
  swapDevices = [{
    device = "/var/lib/swapfile";
    size = 16*1024; # 16 GB
Bootloader
Sysyemd-boot is the recommended bootloader. The following example demonstrates how to enable systemd-boot in your configuration:
Users
  users.users.alice = {
    isNormalUser = true;
    initialPassword = "pw123";
NixOS installation
# cd /mnt
# nixos-install
after installation: Run passwd to change user password. if internet broke/breaks, try one of the following:
