Nix (command)
Revision as of 16:02, 7 September 2025 by Malix (talk | contribs)
Introduction to Nix
Tools and applications
Disambiguation: This article is about the new nix command. Not to be confused with the Nix ecosystem, the Nix language or the Nix package manager.
This article is about the new nix command and all of its subcommands. The new nix command is intended to unify many different Nix package manager utilities that exist currently as many separate commands, eg. nix-build, nix-shell, etc.
See the Nix manual for a complete reference.
Enabling the nix command
In nix 2.4, the nix command must be explicitly enabled. You can do this in a few different ways.
As an individual invocation
nix --experimental-features nix-command build ...
By setting it in the nix configuration
≡︎ ~/.config/nix/nix.conf
experimental-features = nix-command
On NixOS, by setting it in the NixOS configuration
On NixOS you can't edit /etc/nix/nix.conf directly, so you have to set it through the NixOS configuration instead
❄︎ /etc/nixos/configuration.nix
{ pkgs, ... }: {
  nix.settings.experimental-features = [ "nix-command" ];
Tip: In order to affect your NixOS system by your nix-language-specific changes you must first evaluate it:
$ nixos-rebuild switch --sudo
Switching from nix profile to nix-env
Warning: Using nix-env is not recommended.
Once you installed a package with nix profile, you get the following error message when using nix-env:
$ nix-env -f '<nixpkgs>' -iA 'hello'
error: --- Error ----------------------------------------------------------------------------------------------------------------- nix-env
profile '/nix/var/nix/profiles/per-user/joerg/profile' is incompatible with 'nix-env'; please use 'nix profile' instead
To migrate from nix profile to nix-env, you need to delete your current profile:
Warning: This will delete packages that have been installed before, so you may want to back this information before running the command.
$ rm -rf /nix/var/nix/profiles/per-user/$USER/profile
New equivalents to old commands
# create a store derivation for a package defined in the current directory's default.nix
old$ nix-instantiate -A somepackage
# assumes you are now using flakes
new$ nix eval .#somepackage.drvPath
# alternative option
new$ nix derivation show .#somepackage | jq '.[keys[0]]' | nix derivation add
