Revision as of 13:45, 14 February 2026 by Nekohepott (talk | contribs) (Created page with "Это руководство служит вспомогательным руководством для [https://nixos.org/nixos/manual/index.html#ch-installation оффициального руководства]. Оно описывает установку NixOS как полноценной операционной системы, смотрите Nix Installation Guide.")
Это руководство служит вспомогательным руководством для оффициального руководства. Оно описывает установку NixOS как полноценной операционной системы, смотрите Nix Installation Guide.
In addition to covering the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
Installation method
Making the installation media
"Burning" to USB drive
From Linux
From macOS
From Windows
  1. Download USBwriter.
  2. Start USBwriter.
  5. Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Partitioning
Legacy Boot (MBR)
  • o (dos disk label)
  • n new
  • 1 (partition number [1/4])
  • n
  • p
  • 2
  • default (fill up partition)
  • w (write)
UEFI
  • g (gpt disk label)
  • n
  • 2048 first sector
  • t
  • 1 (EFI System)
  • n
  • 2
  • w (write)
Format partitions
# mkdir -p /mnt/boot
NixOS configuration
Most essential changes:
Swap file
  swapDevices = [{
    device = "/var/lib/swapfile";
    size = 16*1024; # 16 GB
Bootloader
Users
  users.users.alice = {
    isNormalUser = true;
    initialPassword = "pw123";
NixOS installation
# cd /mnt
# nixos-install
