NixOS Installation Guide
This guide serves as a companion guide for the official manual. It describes installation of NixOS as a complete operating system. For instructions on installing Nix within an existing operating system, refer to the Nix Installation Guide.
In addition to covering the steps from the official manual, it provides known good instructions for common use cases. When there is a discrepancy between the manual and this guide, the supported case is the one described in the manual.
Installation target
- regular (Intel or AMD) desktop computers, laptops or physically accessible servers, covered on this page
- SBCs (like the Raspberry Pis) and other ARM boards, see NixOS on ARM
- cloud and remote servers, see NixOS friendly hosters
Installation method
- The classic way, booting from the installation media. (Described below.)
- Booting the media from an existing Linux installation
Making the installation media
"Burning" to USB drive
From Linux
- Find the right device with
lsblkorfdisk -l. Replace/dev/sdXwith the proper device in the following steps. - Copy to device:
cp nixos-xxx.iso /dev/sdX
From macOS
diskutil list, let's saydiskX. - Unmount with
diskutil unmountDisk diskX. - Burn with:
sudo dd if=path_to_nixos.iso of=/dev/diskX
rdiskX instead of diskX can makes a large speed difference. You can check the write speed with iostat 2 in another terminal.
From Windows
- Download USBwriter.
- Start USBwriter.
- Click 'Write'
Legacy bios boot
UEFI boot
Connecting to the internet
Wired
Tethered (Internet Sharing)
Wireless
Using the "Applications" tab at top
left or the launcher bar at bottom, choose a terminal application and from there launch nmtui. This will allow you to 'activate' a (wireless) connection - your local SSIDs should be visible in the list, else you can add a new connection. When the wireless connection is active and you have tested it, it is likely the install app which launched on startup has not detected the new connection. Close down the install app, and reopen it from the launcher bar at the bottom of the screen. This should then find the new connection and proceed.
The minimal OS wifi may also be set up using nmcli: nmcli device wifi connect ESSID password PASSWORD
Partitioning
Legacy Boot (MBR)
- o (dos disk label)
- n new
- p primary (4 primary in total)
- 1 (partition number [1/4])
- 2048 first sector (alignment for performance)
- +500M last sector (boot sector size)
- rm signature (Y), if ex. => warning of overwriting existing system, could use wipefs
- n
- p
- 2
- default (fill up partition)
- w (write)
UEFI
- g (gpt disk label)
- n
- 1 (partition number [1/128])
- 2048 first sector
- t
- 1 (EFI System)
- n
- 2
- w (write)
Format partitions
- Bcachefs#NixOS installation on bcachefs
- Btrfs#Installation of NixOS on btrfs
- LVM#Basic Setup
- ZFS#Simple NixOS ZFS on root installation
# mkdir -p /mnt/boot
NixOS configuration
Most essential changes:
- keyboard layout, ie
services.xserver.xkb.layout - networking (wifi), see below for fix if it breaks
- install editor to edit the configuration
Swap file
swapDevices = [{
device = "/var/lib/swapfile";
size = 16*1024; # 16 GB
Bootloader
Users
users.users.alice = {
isNormalUser = true;
initialPassword = "pw123";
NixOS installation
# cd /mnt
# nixos-install
- wpa_supplicant flags to connect to wifi
- Brand servers may require extra kernel modules be included into initrd (
boot.initrd.extraKernelModulesin configuration.nix) For example HP Proliant needs "hpsa" module to see the disk drive.
